I started reassembling my D44 this afternoon and ran into a problem. After installing the spring and the drive dog gears??, started to install the "C" clip that holds this portion togetheron the axle shaft, but the groove in the stub shaft is just barely visable, not enough for the clip to go into. I could not get the hub to go back any further, am I missing something, if so what do I need to do to get the clip into place?? Thanks, Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Born Psycho
![]() Join Date: Feb 2001
Re: D44 question an help
reach around on the back side and push the axle shaft outward. that has happened to me several times over the years and a little push always works for me.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Will do Thank you! Harold
If that doesn't work (usually does) someone installed Ford shafts in your Chevy housing.
