Old 10-13-2008, 01:09 AM   #1
my70chevyc10
my70chevyc10's Avatar
Timing Mark
Please help im going to do a compleate tune up on my 7o c10 swb it has a 350. I have new MSD wires and cap an rotor with a stock chevy HEI. I am having a hard time seeing my timeing mark on the driverside i have the p/s pump in the way and on the pass side is the alternator an i cant see the timing tab. So how do i time my truck if i cant see the tab.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 10-13-2008, 04:59 AM   #2
JimKshortstep4x4
Re: Timing Mark
The stock location of the tab is on the drivers side. My thought would be to move the PS pump if needed.
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-13-2008, 08:30 AM   #3
68_chop_top
68_chop_top's Avatar
Re: Timing Mark
With the engine stopped, wipe off the timing tab so you can at least see it. Wipe off the balancer and use chalk over the timing mark. Make sure you are in the shade, inside the garage, or in the evening. It is close quarters but there should be enough room between the water pump and the power steering pump to see the mark. The chalk makes it easier to see the mark with the timing light.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 10-13-2008, 11:24 AM   #4
cdowns
cdowns's Avatar
Re: Timing Mark
X2 what he said//also helps if you have a step stool to stand on by the drivers front wheel
Old 10-13-2008, 11:20 PM   #5
my70chevyc10
Re: Timing Mark
Thanks guys I just cot done with it today and the timing mark is at the top I had to look between the waterpump and the timing belt cover stright down.
Old 10-13-2008, 11:26 PM   #6
El Jay
Gone to greener pastures
Re: Timing Mark
Methinks you may have an engine that is newer than your truck.
That's where it was on my old '76 GMC.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
