Old 10-13-2008, 01:29 PM   #1
drewdude92
72 chevys 4 life
drewdude92's Avatar
anyone used this before?
im thinkin about gettin one of these it will be sucking colder air in
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 10-13-2008, 02:03 PM   #2
straitnate14
straitnate14's Avatar
Re: anyone used this before?
Good luck noticing any power increase, looks pretty gimiky to me. If you want forced induction thats not it.
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 10-13-2008, 02:21 PM   #3
drewdude92
72 chevys 4 life
drewdude92's Avatar
i dont know yeah thats kind of what i was thinking how do you think i should go about it?
Old 10-13-2008, 02:34 PM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
I was reading "How to build Max Performance Chevy Small Blocks on a budget" by David Vizard and he reckoned that changing to outside air feed from a shaker hood scoop on his Transam at 100F against drawing in underhood air at 190F he gained 25 ft/lbs of torque across the rpm range equating to 26HP at 5500rpm. Thats not to be sneezed at, most modern cars draw in nice cool air from outside the hood for a reason!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-13-2008, 02:37 PM   #5
Senator350
Senator350's Avatar
for sure.. cold air intakes are just plain good sense.
now... OUR underhood temps vs underhood temp of a coupe?
if i thought my intake charge was getting really warm air, i'd buy one of these in a heartbeat. i've had cold air intakes on just about everything else i've ever owned.
maybe someday when i have a couple extra dollars laying around
RN U OVR
Senator350 is offline   Reply With Quote
Old 10-13-2008, 03:35 PM   #6
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
If its not horribly expensive I think it would be worth it. Your getting a colder air charge from outside of the engine compartment. I don't know what kind of ambient temperatures there are where you live, but theres a +1% power increase per 10 degree drop in ambient temperature. You may not get enough to feel but it will be there all the same. Carbs like their cool dense air....
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 10-13-2008, 03:57 PM   #7
mekdad
mekdad's Avatar
what about birds and bugs?
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 10-13-2008, 04:08 PM   #8
RocketChevy56
put a nice screen on the inlet tubes in the radiator support? I had a '86 swb and the stock intake tube went to the front radiator support. I don't recall having too much trouble with things crawling or getting sucked in the tubes. anything that came in, the filter catches most of any debris
Old 10-13-2008, 04:14 PM   #9
prg machine
prg machine's Avatar
here in Oregon you would drownout the engine.
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 10-13-2008, 06:59 PM   #10
hotrodxy
hotrodxy's Avatar
ford used that set up on their falcon 500, with a tear-drop hood. and called it a thunderbolt. i think it worked for them
1967 LWB 4speed-current project
1970 LWB 3 speed -stolen
1980 Z28 - sold
1968 Barracuda Big block- sold
1969 Firebird 400/400-sold
hotrodxy is offline   Reply With Quote
Old 10-13-2008, 07:02 PM   #11
hotrodxy
hotrodxy's Avatar
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
here's one
1980 Z28 - sold
Old 10-13-2008, 07:10 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the thunderbolt was based off a fairlane, not a falcon.
There are other advantages to cool air;
you can run more timing
you can reduce octain requirements
more power/torque
better MPG
cleaner emissions
with the frontal area, there will be a little bit of ram air effect one you are up to speed, but it would be marginal at best.
Now, granted, you won't get ALL of those... it depends on what way you tune and drive it.
Later model cars not only have it, but are required to maintain it under federal smog laws... not just new cars, but I think 74 was when it was required on cars. That paper hose that rotted out and no one bothered replacing (in many states) was a corm of cold air induction.
The part that sucks, you'll have to cut huge holes in your core support to do it properly. I would use smooth pipe instead of that ducting, just like on the exhaust, smooth is better than bumpy.
As for the bug comment, that's what your air filter is for.
Old 10-13-2008, 07:27 PM   #13
cdowns
cdowns's Avatar
if you get one get the one that has little propellers in them they're the hot ones
Old 10-13-2008, 07:33 PM   #14
t&tkennels
t&tkennels's Avatar
Ive seen test on these, & they made some good horse power!
t&tkennels is offline   Reply With Quote
Old 10-13-2008, 07:47 PM   #15
hotrodxy
hotrodxy's Avatar
You are right longhorn man I was typing faster than thinking
1980 Z28 - sold
Old 10-14-2008, 12:56 AM   #16
Longhorn Man
its OK, I'd get flamed for knowing ford info before you'd get flamed for NOT knowing it.
Old 10-14-2008, 01:48 AM   #17
90\87Formula
90\87Formula's Avatar
Here's a pic of a member's truck. I don't remember who's truck it was.
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 10-14-2008, 05:49 AM   #18
Longhorn Man
i was trying to find that photo last night.I don't remember it being a member's truck... but I pirated it off of here back in 01 or 02.
Old 10-14-2008, 06:12 AM   #19
GMC Jim
GMC Jim's Avatar
I have a junkyard aircleaner ( came from a 79 Cadillac El Dorado) air cleaner fits the 4 bbl Rochester fine and has an intake tube 4 inch diameter. Used a metal 4" flex hose ( like for a clothes dryer ) and air intake is on left (drivers side) . Slanted the flex tube down to near bottom of wheel well. Draws outside air but with no ram effect.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 10-14-2008, 06:20 AM   #20
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Talking Re: anyone used this before?
I had one on my 71 C-10 454BBC and from what I noticed there was a big diference in Performance! I plan on buying a set up for my 72 !!!
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 10-14-2008, 07:48 AM   #21
67ChevyRedneck
67ChevyRedneck's Avatar
Y'all can laugh if you want, but this made a very noticable difference in my S-10, especially in 4th and 5th gear. No mpg improvement, but I didn't lose either. Will I be racing with it anytime soon? HELL NO But it really helps my little truck fly down the highway better now
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-14-2008, 09:50 AM   #22
drewdude92
72 chevys 4 life
drewdude92's Avatar
i think ima price them but ill look into building one first ill get pics if i get around to it
Old 10-14-2008, 10:08 AM   #23
rambler
MOVE OVER
rambler's Avatar
I remember cleaning out the standard cold air intake in the 93 surburban.. I pulled a dead bird out of there.. ran better after that... (till the wife dumped the transmission!)
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 10-14-2008, 10:12 AM   #24
drewdude92
72 chevys 4 life
drewdude92's Avatar
o dang!! haha did ya eat it? im sure it would of been clean
