Old 10-13-2008, 09:35 PM   #1
kamikazekyle05
kamikazekyle05's Avatar
Fuel Line Help
Hey Guys, i kinked my metal line going to my edelbrock 1901 carb. on my 327, i want to replace it with a steel braided line and a inline filter(from the fuel pump to the carb.) My question is, how do AN fittings work with steel braided lines, do they thread into the line or clamp? Also can anyone help me pick the right parts or suggest something good? Thanks Guys, Kyle
kamikazekyle05 is offline   Reply With Quote
Old 10-13-2008, 09:55 PM   #2
hotrodxy
hotrodxy's Avatar
Re: Fuel Line Help
cutting braided lines and putting an lines on is a pain in the a**, buy a kit that has every thing cut to length. i think edelbrock make everything you need
1967 LWB 4speed-current project
1970 LWB 3 speed -stolen
1980 Z28 - sold
1968 Barracuda Big block- sold
1969 Firebird 400/400-sold
hotrodxy is offline   Reply With Quote
Old 10-14-2008, 08:59 AM   #3
jamesi20
jamesi20's Avatar
Re: Fuel Line Help
http://store.summitracing.com/largei...g=edl-8134.jpg this is what I just got.I cut my braided steel hose with a sharp chisel and a large hammer.I put a block of wood down,set the hose on it and gave it a good smack...it cut it very smooth with no fraying of the braided stainless.Made it real easy to put the an-6 fittings on
jamesi20 is offline   Reply With Quote
Old 10-14-2008, 10:11 AM   #4
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Re: Fuel Line Help
hey james, you put your filter and such on yet? I'd like to see a pic of it all together, I just put my fuel pump on last night and I plan on starting the plumbing this weekend on the new engine. I was looking at steel braided lines for the fuel system and trans. cooling lines. thanks.
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 10-14-2008, 10:20 AM   #5
big_al_71
big_al_71's Avatar
Re: Fuel Line Help
I bought braided lines by the foot and made all my own lines with an fittings. I only had one small leak after I started the motor and it was on the lines that attach directly to the carb and I did not make those I bought the kit so go figure. I used those fitting on my motor everywhere I could and knock onm wood no leaks...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-14-2008, 10:39 AM   #6
RocketChevy56
Re: Fuel Line Help
That looks awesome!! I have the same March Serpentine kit too. I never messed with the DIY braided stuff before. What all is involved?
(sorry kamikaze, didn't mean to hijack the post)
Old 10-14-2008, 07:40 PM   #7
kamikazekyle05
Re: Fuel Line Help
Well i think im gonna go back with the filter in the carb, now i jus need the line, big al, how do the fittings go on the hose?
Old 10-14-2008, 09:58 PM   #8
big_al_71
big_al_71's Avatar
Re: Fuel Line Help
kamikazekyle05 & RocketChevy56
The way it works is they are push in and then as you tie them against the other end it creates a leakproof seal.
I used both styles the push on and the screw in type...I used them on my tranny lines on the tranny side as well as on the cooler side and you can also see it from the fuel pump to the filter to the carb. Also I used braided line with fitting from the tank to the pump. I am posting a couple of picts so you can get an idea.
here is a link to the ones I used
http://www.bicknellracingproducts.co...f5587535ed5df3
Old 10-14-2008, 10:00 PM   #9
jamesi20
jamesi20's Avatar
Re: Fuel Line Help
here ya go,I hope I can do this,I haven't posted many pictures...
Old 10-14-2008, 10:08 PM   #10
kamikazekyle05
Re: Fuel Line Help
Thanks Guys!
Old 10-15-2008, 09:37 AM   #11
RocketChevy56
Re: Fuel Line Help
Looks awesome, hope i can do it half as good as you guys. I appreciate the help. I might have to track you down at a later date when I get confused again
