Old 10-14-2008, 12:06 AM   #1
1969 k/10
1969 k/10's Avatar
ring gear
Does any body know what the torque specs. are on the ring gear bolts for a 12 bolt eaton posi diff.?
Also what are the torque specs for the carriers bearing cap?
1969 red k/10 with sb350
4.11 gear ratio, front disk, 3 speed automatic
1969 k/10 is offline   Reply With Quote
Old 10-14-2008, 12:33 AM   #2
1969 k/10
1969 k/10's Avatar
Re: ring gear
Thank you! that helps alot.
Where can i buy this manual?
Old 10-14-2008, 04:51 AM   #3
JimKshortstep4x4
Re: ring gear
Are you using a 1 ton axle in your K-10?
The torque specs listed are for a 1 ton axle.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-14-2008, 05:32 AM   #4
cdowns
cdowns's Avatar
Re: ring gear
the overhauk manuals are available as reprints from most vendors on the site or are common on ebay price is around $25plus shipping about the best money you can spend on your truck
Old 10-14-2008, 11:13 PM   #5
1969 k/10
1969 k/10's Avatar
Re: ring gear
Jim
no its for a half ton
Old 10-15-2008, 04:23 AM   #6
JimKshortstep4x4
Re: ring gear
The torque specifications for the 1/2 ton ring gear bolts is 50 lb./ft.
The torque specification for bearing cap bolts is 55 lb./ft.
Jim
Old 10-15-2008, 04:53 PM   #7
1969 k/10
1969 k/10's Avatar
Re: ring gear
Jim
thank you
