Old 10-14-2008, 12:49 AM   #1
primered_junk
ASE master tech/machinist
primered_junk's Avatar
Houndstooth seat question.
I have a 72 custom deluxe, the seat is still wearing the original upholstery. It seems to be a rare color combo, it is white with the scroll pattern in the middle, and orange and white houndstooth. I cant find that combo anywhere, any ideas?
"I sit here and I pray in my broken down Chevrolet....."
primered_junk is offline   Reply With Quote
Old 10-14-2008, 01:34 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Houndstooth seat question.
is it hounds tooth, or plaid?
Old 10-14-2008, 08:06 AM   #3
This?
Or this?
Old 10-14-2008, 10:33 AM   #4
primered_junk
def. houndstooth.
Old 10-14-2008, 11:03 AM   #5
72highlander
Sophomore Member
72highlander's Avatar
that's not factory, i bet your truck is a highlander and should have the plaid like in the second pic. with the below eyeline mirrors, tilt, custom deluxe, and parchment interior, i bet it is. it should say highlander or special promotional on the glove box. if it is it should have orange plaid seat inserts. i attached some pics of mine and of a highlander brochure.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 10-14-2008, 11:26 AM   #6
The reason everybody is questionong is because Houndstooth only came in the Cheyenne Supers.A Custom Deluxe would have Custom Cloth which is a lacey pattern polyester in a slid color matching the vinyl.Unless it`s a Highlander,which yours may be because they`re based on Custom Deluxes and would have Parchment vinyl.
Old 10-14-2008, 12:28 PM   #7
primered_junk
That's odd. It does have the highlander package listed on the glovebox. But it was also a special order truck. I got it from the original owner he gave me a mountain of paper work, owners manuals, warranty card, maint. records, protect-o-plate etc. I have the special order number but no broadcast sheet. He swore that nothing had ever been changed exept the engine was rebuilt in 1984. I also have (but not currently in the truck) factory tach and vacuum gauge, am/fm push button radio and floor mats. Is it possible it was ordered like that, or does the old man have allzhiemers? If it does need the plaid seat, does any one make re-pop covers?
Old 10-14-2008, 04:14 PM   #8
sameyrasmea72
sameyrasmea72's Avatar
I vote allzhiemers, I have never heard of an orange houndstooth in trucks and and have never seen a houndstooth seat with a scroll pattern. I have never heard of a factory vac. guage in a regular truck.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-14-2008, 04:27 PM   #9
primered_junk
That's what I am starting to think. The vac gauge is original to the truck it's on the glovebox label, along with the tach, volt and other gauges. The seat issue makes me question the whole purchase. The question still remains, where can I find a plaid cover.
Old 10-14-2008, 04:36 PM   #10
sameyrasmea72
I think the plaid material is available somewhere, but it is the scroll pattern that is not reproduced, but maybe yours is ok, someone will chime in. If you get a chance post a picof the option sticker I have never seen the vac guage listed on a truck.
72 Cheyenne Super
Old 10-14-2008, 04:44 PM   #11
Longhorn Man
yes, let me jump on the option band wagon here.
Does it say COPO anywhere on there on the SPID?
Old 10-14-2008, 05:21 PM   #12
primered_junk
I have no camera, the options on the SPID are as follows
1BX230 body side moulding
1B9210 door edge guards
1D6410 Below eye line mirrors
165010 Heavy rear springs
1LS910 350 eng
1N3310 comfortilt steering
1PA120 Deluxe wheel covers
1U6312 AM/FM pushbutton
14G820 Special promo pkg
126260 Custom Deluxe
16810 Highlander orange
1A1120 tinted glass
1B8530 belt moulding
1C6020 four seasons a/c
1F110 Front/rear shocks
1J7010 hydraulic brakes
1M4910 turbo hydramatic
1N4010 power steering
1UF210 cargo lamp
1U3720 front/rear chrome
125323 gauges ammeter, oil, rpm, temp vac
145810 white/red orange/white
SP. Order# QQQ166
Does this tell us anything?
Old 10-14-2008, 05:48 PM   #13
I don`t recall ever seeing SP.Order# on the spid.Could this be a copo?I`ve never seen the gauges all grouped together in one option.
Old 10-14-2008, 06:03 PM   #14
Longhorn Man
copo is normally typed out on the SPID.
I'll have to see if I can find that RPO 125323 ... doesn't even look like the right kind of code.
mine (with no vac guage) is 1Z5320
Old 10-14-2008, 06:31 PM   #15
primered_junk
There is a bad spot on the spid right on the line between the numbers, if you can find the correct number I'd like to write it down.
Old 10-14-2008, 07:18 PM   #16
Longhorn Man
without seeing it in any of my books, I would say that it should be 1Z5323 instead of 125323... since it is like one digit off a normal guage cluster.
Old 10-14-2008, 08:15 PM   #17
67CHIP72
STOLEN
67CHIP72's Avatar
Is there anyone you know with a camera that could take a picture of the SPID and email it to you so you can post it here? Good luck.
In Search Of
67CHIP72 is offline   Reply With Quote
Old 10-14-2008, 09:34 PM   #18
71 super
71 super's Avatar
Is it possible since the scroll is correct for the highlander seat, that the inserts were replaced at some point? I realize that the original owner said it was correct but that would make it one in several hundred thousand as would the vac cluster. The tach should be a seperate option to its self not included in the cluster option. What are the first digits on the vin for the plant the truck was built in? Also does the wheel based match the truck- i.e 115 or 127 ? This just does not match up. Not doubting the COPO option but how many of these trucks actually rolled with the COPO option, unless they were some specialized fleet vehicle?
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-14-2008, 10:17 PM   #19
Longhorn Man
COPO isn't an option, and I would speculate that hundreds of thousands rolled out the COPO program... as fleet/specialty trucks... and ONLY as such.
Old 10-14-2008, 11:34 PM   #20
72highlander
Sophomore Member
no one reproduces the whole seat cover. sms auto fabrics has the plaid and they can even build the scroll, but not put together the whole cover. the vinyl they use to make the scroll is cheap vinyl and when they emboss the scroll it is not as deep as the factory. you should be able to reuse your scroll inserts, buy the plaid, and have a cover made from the rest. i talked to a guy about doing one and he said that he could, he reproduces factory covers in vinyl and houndstooth. when i bought my plaid it was $85 per yard and it takes about a yard and a quarter. here is a link to sms.
http://www.smsautofabrics.com/
Old 10-14-2008, 11:46 PM   #21
Longhorn321
Size Matters
Longhorn321's Avatar
Got any pics of that "Custom Cloth"?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 10-15-2008, 12:03 AM   #22
1972_K10
1972_K10's Avatar
Here is 2 pictures of my faded original 1972 Custom Deluxe seat cover.
1972 K10 Custom Deluxe SWB 350/350/205 AC
About to be put back together after sitting in pieces for 23 years. My father (original owner) says "IT'S ABOUT TIME!
1972_K10 is offline   Reply With Quote
Old 10-15-2008, 06:58 AM   #23
I was thinking the houndstooth could have been sewn in.My`70 CustomCamper/30 had the Parchment interior w/Custom cloth full foam seat and Winnebago had sewn-in a plaid cloth.
I`ve never seen a special order number on a spid.That`s what has me wondering.The tach should be an option in itself,regardless of whether the vacuum guage was there or not.But...if it`s some kind of an exception then anything is possible.There would be no "correct" number for that option.
I can`t imagine why someone would COPO a truck that already was a promotional package (mass order) just to have the fabric changed (that made it that package) and to get a vaccuum gauge.
Old 10-15-2008, 09:55 AM   #24
primered_junk
This all has me confused, the bench that 72 k10 posted has the same scroll as mine, just different inserts. I do in fact know it was a special ordered truck. It was ordered December 1971, by Tom Blackburn Chevrolet in Arlington Texas, it was the owners personal truck that was used for dealer promotions at the now defunct Green Valley Raceway where they campaigned a 70 camaro drag car. I purchased the truck in march from Mr. Blackburns son, It had been sitting in on jack stands in storage since 1989. The R.PO. for the cluster is in fact 1Z5323. My brother is supposed to bring my camera back tonight, I'll get a pic of the SPID
Old 10-15-2008, 08:49 PM   #25
Joesjunk
Joesjunk's Avatar
Interesting truck, cant wait to see the option list!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
