10-14-2008, 02:01 AM | #1 |
No kick down blues
Hey guys I was wondering if any of you TH400's out there had an idea about the ele. kick down module. My pick up doesn't have one, I know Lokar sells one for $100 but I was wondering if there was a low cost fix for this.
Thanks in advance |
10-14-2008, 09:39 AM | #2 |
It's a catastrophic success.
Re: No kick down blues
All you need is a switch off the gas pedal that closes and sends 12v to the tranny.Auto parts store should have one farely cheap.
10-14-2008, 09:45 AM | #3 |
Hand Crafted C-10
Keep your eyes pealed at the swap meets, parts board, etc. The stock switches are still fairly common and they can be tested with a multimeter.
The landing pad, where the switch strikes, can be a challange to find but you can make your own strike pad pretty easy. If your truck came stock with a T400, you may still have the wiring in your harness. |
10-14-2008, 09:54 AM | #4 |
I would love to give you some good advice, but I need the same thing you do!
10-14-2008, 11:06 AM | #5 |
Chevy Truck Addict
I've got a pedal switch if anybody needs one.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
10-14-2008, 11:55 AM | #6 |
sneakysnake: thanks for the pick i've never even seen one.
ETsC10: i'm going to scower the junkyars in spokane so with luck... Lucky hey i saw your truck on craigs list whats up with that??? c10-driver: whats a pedal switch look like and how does it attach? I'm interested |
10-14-2008, 12:35 PM | #7 |
Between Trucks...
I sprung for the Lokar unit, works great.
Beat it to fit, Paint it to match... |
10-14-2008, 01:15 PM | #8 |
10-14-2008, 04:43 PM | #9 |
ASE master tech/machinist
I used a regular wide open throttle switch on my GMC 454/400 combo, it was around $10 at my local speed shop. There are many brackets available to adjust the position of the switch to make your right foot happy.
Universal for most carbs N.O.S #15640 Edelbrock carbs, edelbrock #72280
"I sit here and I pray in my broken down Chevrolet....." |
10-15-2008, 02:50 AM | #10 |
Chevy Truck Addict
The pedal switch is the small picture in post 2. It mounts near the gas pedal. When you "step" on the gas, the round tab sticking out the side of the switch is pushed by the pedal rod and the switch closes. I'm definitely no expert on the subject... I run a lokar kickdown on my 700R tranny. The donor cab I bought was from a big block truck with the Turbo 400 and about all I know about it is where I took it off.
10-15-2008, 03:19 PM | #11 |
ya i found one for 75 bucks so i think i'm go to spring for the lokar unit. Thank for all the info guy's
i love this site |
10-15-2008, 03:28 PM | #12 |
I'M TRUCK CRAZY!
Interesting...... is there something like this for a TH350...??? will this work?
10-15-2008, 04:00 PM | #13 |
Between Trucks...
TH350 kickdown is cable operated.
10-15-2008, 04:01 PM | #14 |
The t350 is not electrical so it won't work.
69 Chevy 4x4 383 Power |
10-15-2008, 05:06 PM | #15 |
I'M TRUCK CRAZY!
oh, didn't know the 400 was electric. My boss has a 400. (so he says) I will have to look at his next time he drives it to work. He either doesn't have a kick down or it is a cable wich would mean it's a TH350. Right? I know it's a 3speed auto
10-16-2008, 04:26 PM | #16 |
sinister and Alex1: How was the adjustment with the lokar unit? Was it difficoult to find the right adjustment? I read an online install and it sounded real easy but you know how the mags. can be...
10-16-2008, 08:01 PM | #17 |
Between Trucks...
Easy to adjust. You can feel the switch engage when you tug on the cable. Just adjust so it works at WOT.
10-16-2008, 10:48 PM | #18 |
Any pics of the lokar kickdown installed? I am looking for a place to mount a box.
10-16-2008, 11:21 PM | #19 |
Here is a write up, I just ordered one from summit. http://67-72chevytrucks.com/vboard/s...ad.php?t=70874
11-03-2008, 12:14 PM | #20 |
I'M TRUCK CRAZY!
What is this switch called?
Trying to find it at the parts store. http://67-72chevytrucks.com/vboard/a...1&d=1223991486 |
11-03-2008, 12:16 PM | #21 |
I'M TRUCK CRAZY!
Also, What vehicle should i look under to get to it?
11-03-2008, 05:15 PM | #22 |
PROJECT 7DEUCE
I also bought the lokar unit and so far just up and down the drive way it works great...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-03-2008, 06:46 PM | #23 |
I'M TRUCK CRAZY!
11-03-2008, 09:23 PM | #24 |
PROJECT 7DEUCE
mmmmmmmmmm not long at all.
