Old 10-14-2008, 06:28 AM   #1
tommypic
tommypic's Avatar
what goes 1st
when I am replacing the floor pan , center hump , rocker panel inner and outer , kick panel . why I don't know is it was cut out by PO . I have to replace the lower part of door post too on the o/s , below the door bolt holes . The piece that has the big hole that bottom of fender bolts to is that 2 pieces . There are 2 small bolts and a large hole . pic gives you an ides of what is going on . oh yea should I hang the doors before I start doing this
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 10-14-2008, 07:21 AM   #2
soba_03
soba_03's Avatar
Re: what goes 1st
my only concern is that if everything that you have mentioned is already cut out then I'm worried that your cab might have spread out a bit. I would square your cab first, then my thoughts would be floor pans, trans cover, rockers, then door post. But i'm sure someone who has been this indepth on one will chime in on the most logical process.
soba_03 is offline   Reply With Quote
Old 10-14-2008, 07:22 AM   #3
JimKshortstep4x4
Re: what goes 1st
Hmmm!, It looks like some assembly is required!
I would start with the pillar post repair as the inner rocker and outer rocker attaches to it. Attached is a schematic of the the pillar post and rockers.
You will want to use the door for checking clearances.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-14-2008, 08:59 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: what goes 1st
I agree, Start where its important, around the doors. The middle will kinda take care of its self.
sneakysnake is offline   Reply With Quote
