Old 10-14-2008, 01:44 PM   #1
Rat72
Rat72's Avatar
Bolt On Electric Fans?
I'm looking for a bolt an electic fan/shroud set up. I believe CPP makes one, are there others out there?
Thanks,
Whit
Rat72 is offline   Reply With Quote
Old 10-14-2008, 02:32 PM   #2
Senator350
Senator350's Avatar
Re: Bolt On Electric Fans?
flex-a-lite makes a ton of different sized fans in shroud.
measure your radiator mounting surface, go to their site, and pick one.
reccomended
RN U OVR
Senator350 is offline   Reply With Quote
Old 10-14-2008, 03:14 PM   #3
airdale94
airdale94's Avatar
Have a look in the FAQ "Another Cheap Elec. Fan Build", You can get a Jeep fan that sits in a stock small block fan shroud. A slot in the botom and drill 2 holes is all that's required. The fan is available new for $65. Unless you want something with a little more "bling".
airdale94 is offline   Reply With Quote
Old 10-14-2008, 05:03 PM   #4
cparman
sharp as a marble
www.spalusa.com
I have used their stuff before, and depending where you are they build a dual 12" setup that should be an easy install to a stock radiator in our trucks
cparman is offline   Reply With Quote
Old 10-14-2008, 06:05 PM   #5
Tom Meyer
Check it out at http://www.meyerbrosrods.com/photos/...icture133.aspx
This is a 3000 cfm fan with a Jegs aftermarket radiator. I made the bottom braket and the top brakets for mounting the radiator. I could not resist the $170.00 radiator price tag....
Tom Meyer is offline   Reply With Quote
Old 10-14-2008, 11:47 PM   #6
fastom
That's right, it's Copper!!
fastom's Avatar
Old Air Products makes one! http://www.oldairproducts.com/catalo...oducts_id=2408
I used this one and it worked great.
fastom is offline   Reply With Quote
Old 10-15-2008, 07:23 PM   #7
Rat72
Rat72's Avatar
This flex-a-lite is the perfect size but a lot of money for something that requires a little fabrication. I don't mind the fabrication part, it's the money!
Old 10-15-2008, 08:41 PM   #8
big_al_71
big_al_71's Avatar
I went with "Flexalite" I did not mind spending $475.00 on them. I was not going to risk my new built motor to save couple of hundred dollars...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-15-2008, 10:00 PM   #9
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
do any of these kits come "plug and play"?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 10-15-2008, 10:06 PM   #10
Senator350
Senator350's Avatar
like... will connect to your computer via usb?
dude. you have to strip your fan and clutch assy off your harmonic ballancer, remove your fan shroud, figure out how you're going to install the new fan and shroud, wire them with ign 12v, fuse the wiring (maybe), run a thermostat if your fan has variable speed...
not much plug and play.... unless you want to bolt the electric fan blades to your stock fan assy.
RN U OVR
Old 10-15-2008, 10:47 PM   #11
sixty8c10
sixty8c10's Avatar
what I mean is, does it come with everthing you need to make it work. you don't have to go and buy a bunch of extra little pieces relays, switches, etc. to hook it up, if i'm gonna order something i don't wanna have to make 30 trips to the parts store to make it work....I have already ran my power wire for this. My truck is in the reassembly stage (check my sig) and this is the prime time to be putting one of these in.
Old 10-16-2008, 11:10 AM   #12
Rat72
Rat72's Avatar
What model did you go with?
Old 10-16-2008, 11:19 AM   #13
smn69
As was mentioned above, check out the FAQ "Another Cheap Elec. Fan Build". I just did this on mine and it was pretty easy. The fan was $80 from an ebay vendor. It is only a two wire fan and fits like it was made for the sbc shroud. A thermostat for the passanger side head and a relay to the fan. Pretty simple mod.
smn69 is offline   Reply With Quote
Old 10-16-2008, 11:28 AM   #14
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We have a dual 12" fan assembly that is as close to bolt on as it gets. I designed it to fot our trucks specificly. It comes complete with everything you need to fit it into your truck. Our systom uses Flex-a-lite fans and gives you choice of materials that the shroud is made from also. Nobody else's that I know of does that. Many board members here have them in their trucks. Here is a link: http://www.classicheartbeat.com/radi...&__related.htm
WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-16-2008, 11:31 AM   #15
Classic Heartbeat
Here is a picture of it... WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 10-16-2008, 11:54 AM   #16
Rat72
Rat72's Avatar
Wow, check out this bad boy! Dual 16" fans and it's a drop-in.
Old 10-16-2008, 01:16 PM   #17
Rat72
Rat72's Avatar
Nice. How does the shroud attach? Will it work on aftermarket radiators (BeCool or Griffin)? What model fans are you using?
Thanks,
Whit
WES
Old 10-16-2008, 02:32 PM   #18
Classic Heartbeat
I do not know about all of the aftermarket radiators. The will fit all of the coper and brass radiators that are direct replacements though. They attach with 6 Stainless steel screws into the top and bottom headers of the radiator. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 10-16-2008, 04:27 PM   #19
fastom
fastom's Avatar
The one I got from Old Air Products is a bolt on unit. It fits in place of the stock fan shroud and it worked great with my Be Cool radiator. All that is needed is a switched 12V supply, no other wiring is needed.
Old 10-16-2008, 05:04 PM   #20
70GMCer
70GMCer's Avatar
FYI.....Make sure your alternator can handle some of these fans. Some pull a hefty amp draw.
I also went with the Jeep fan last Spring. Never any overheating. Stays around 185 to 190 all day long, (even in traffic), and that's with an auto trans cooler in front. I have about $60 total including the used fan & new sensor wiring.
There was a member on here about a year back that was selling them for around $25, but can't remember who it was.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-17-2008, 12:03 AM   #21
Rat72
Rat72's Avatar
Wes-
I'm starting to lean towards running the belt driven fan that came with my LS2 and was looking at your site for shrouds. Seems like there are a bunch of different options; small block, big block, 4x4, air/no air. What is the difference between them?
Thanks,
Whit
Old 12-30-2008, 12:37 AM   #22
extd56
extd56's Avatar
Where did you see this fan at? Thanks
extd56 is offline   Reply With Quote
Old 12-30-2008, 12:51 AM   #23
lyrikz
PITbut
lyrikz's Avatar
Thanks,
Whit
I just got this one. 3500 cfm... Got it for cheap. Refurbished units. Worked perfectly.
You get them on ebay...
$140 bucks...
lyrikz is offline   Reply With Quote
Old 12-30-2008, 01:05 AM   #24
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Wink Re: Bolt On Electric Fans?
I found it at:
http://www.rondavisradiators.com
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 12-30-2008, 09:16 AM   #25
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Anybody get a price on these for our trucks yet? I mean as a set Rad + Fans
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
