tryin to get laid
Question: Welding in pipe notch
So, I'm new to bagging and frame work and all the like. I've enjoyed tinkering with car and bike for a while, but never really went over to the fabrication side. So as far as a welder goes, all I have right now is a Lincoln that plugs into 120. Supposed to push like 130 amps though.
To get to my question, I'm sure that there would probably be issues with trying to build a step notch with such a small welder, but I plan on running air over leaf with a flip kit. So I was going to do a simple notch with pipe. Do you guys think that I can get away with welding with my 120v welder? I do plan on boxing the back side. Also, what size and thickness pipe should I use? Thanks for any help |
Re: Question: Welding in pipe notch
for just a pipe notch, I'd say no prob. A 120v welder will be fine, and I'd use at least a 3/16 thick pipe. Be sure to leave a bit of a gap to fill with the welder since the 120v welder will have a hard time "burning". For example, if you frame is 2" wide, the make the notch 1-3/4" wide.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
a 120 will work thats what i use on my notch, just bevel the edge's and leave an 1/8th inch cap and weld it up...
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
tryin to get laid
Thanks for the advice guys!
FnLow, love that dodge man! |
thanks its a fun truck, im going to put bags on it in a couple weeks then it will be even more fun...
tryin to get laid
Oh, one last question... What would be the best diameter pipe to use and how far up in the frame?
I figured right at 5" since the axle housing is three(?) and no more than 2/3 into the frame (if that makes sense) |
New Member
i was curious,i used a peice of 1/4 drill steam pipe on my notch but i didnt box in the back side,what size plate do most of you guys use when you box it in.thanks
what size, i would do a 2.5" or 3". As for the size plate to use for a backing, 3/16" would work good.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 10-15-2008 at 11:16 AM. |
