Old 10-14-2008, 03:03 PM   #1
gemiii
gemiii's Avatar
Suburban frame question
Is the frame from the same year 2 wheel drive C10 8ft the same as the same year Burb(72). I just bought a 3/4 ton 72 Suburban and I want to lower it and make it a half ton. I have a redone frame from a 1/2 ton Cheyenne. I also have a 89 Burb 1/2 ton that I am going to part, will the suspension fit easy on a 72?
George
gemiii is offline   Reply With Quote
Old 10-14-2008, 04:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Suburban frame question
Before you go doing all that work... the frame is 99% the same betweeen 1/2 ton and 3/4 ton.Theres a few added braces, and beefy suspention parts... nuts and bolts and it all falls off. I just did this myself, 3/4 ton to 1/2 ton conversion.
To answer the actual question though... I *THINK* they are the same, or at least close enough to swap out.
Old 10-14-2008, 04:49 PM   #3
earl87gta
earl87gta's Avatar
only diffrence is the body mounts every thing else is the same. I agree with Longhorn there is not enough difference in the 3/4 and 1/2 frames to make it work removing the body unless you are going to do it any way to paint and pweder coat or c notch or some thing.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-14-2008, 05:04 PM   #4
gemiii
gemiii's Avatar
Thanks for the replies. I should have said that my Cheyenne frame is a 1/2 ton rolling chassis. I was thinking how nice it would be if the burb body could bolt onto it. I am trying to get away from the 8 lugs and 16 inch wheels.
George
Old 10-14-2008, 05:15 PM   #5
earl87gta
earl87gta's Avatar
It will go on with very little work just move the body mounts and your good to go.
Earl
Old 10-14-2008, 07:29 PM   #6
k5kev
New Member
I've dropped my suburban body on a 72 4x4 long bed frame, and ya everybody is pretty much correct, you need to swap out some of the body mounts. Positions 3, 4, & 5 to be exact (position #1 is the radiator support). Here is a pic of #3 installed. Sorry no pics of #4 & #5, haven't bolted them on yet.
The other thing is that the suburban frame is longer, so I cut and welded the rear frame horns on. This extra length also gives you the last body mount,... position #7. I boxed the frame in at the speice and also filled in the truck body mount hole and drilled in (hole saw) Suburban position #6. See attached pics. Hope this helps.
k5kev is offline   Reply With Quote
Old 10-16-2008, 02:02 AM   #7
Frizzle Fry
Frizzle Fry's Avatar
I was gonna mention the rear frame length and "kick-down" but k5kev nailed it.
Frizzle Fry is offline   Reply With Quote
