Old 10-14-2008, 04:08 PM   #1
kizer
Its Deja Vu time again
kizer's Avatar
Drive Shaft is UGLY
Ok, I've been taking my time stripping off all the rust on the back half of my truck. Took the bed off and removed all that is humanly possible in my garage the surface rust and whatever else was on everything below the frame.
Now I have the following left to pounder:
Brake lines, more than likely will replace with stainless
Outer axle ends when I pull the axles and brakes I'll spruce it up
Muffler when ever I address the exhaust
Ebrake cable lines. When ever I get to them
Drive shaft which is a 2 piece, which I'm guessing is because I have a Long Bed.
The drive shaft is a big rusty looking spike between my frame rails.
What did you guys do to yours? Did you just ignore it? Replace it? Or hit it with a wire wheel and remove all the loose stuff and paint it? I don't want to go crazy with it simply because I don't want to deal with having it balanced later, but figured I know I'm not the only one to look at it and thing its UGLY and Dirty.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 10-14-2008, 04:16 PM   #2
ChopperDr
Re: Drive Shaft is UGLY
Take it in to have it balanced. They come back nice and clean. They must clean it up as it's spinning, they sure turn out nice.
Chopper
ChopperDr is offline   Reply With Quote
Old 10-14-2008, 09:50 PM   #3
kizer
kizer's Avatar
Hmm, I never thought of it that way. I'll make some calls tomorrow to see who balances driveshafts in my area.
Old 10-14-2008, 11:38 PM   #4
Hoffman65burb
Hoffman65burb's Avatar
has anyone put a 1 piece drive shaft?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 10-15-2008, 04:14 AM   #5
leftcoast66
leftcoast66's Avatar
You could do it, but just curious why you'd want to?
OP I just wire brushed mine. Worked great for daily driver duty.
leftcoast66 is offline   Reply With Quote
Old 10-15-2008, 07:37 AM   #6
ChopperDr
These guys have a location in Everet. Good place to work with. http://www.drivelinesnw.com/
Chopster
Old 10-15-2008, 09:06 PM   #7
Hoffman65burb
dont you lose torque with a 2 peice?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 10-15-2008, 11:56 PM   #8
kizer
kizer's Avatar
You might loose some torque as a 2piece, but at the same time you gain a 2 piece drive so when my bed raises and lowers my pinion angle stays flatter.
With a 2 piece you lower the chances of blowing U-joints and having drive line vibrations.
Also I have a Long Box.
Old 10-15-2008, 11:57 PM   #9
kizer
kizer's Avatar
Chopster
Thanks I forgot about them.
Old 10-16-2008, 01:08 PM   #10
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Joey~AP is offline   Reply With Quote
