Old 10-14-2008, 04:24 PM   #1
texascowboy593
texascowboy593's Avatar
Tie rod setup on my 59 Apache
Howdy old friends!
I'm finally getting some stuff done of the "Tracy Lee" aka "Flight '59".
Here's my latest problem:
Apparently the inner sidewalls of both front tires have been touching the tie rod ends and there is a GROOVE in the sidewalls now!
Here's the setup as I understand it: CPP 3inch straight drop axle with original tie rod assembly. I told my friend (chief mechanic on Flight 59) that I was gonna change the wheel/tire combo and we could order a different wheel backspacing to bring the tires more out and away from the tie rod ends. He said that wouldn't work... I looked on CPP's site and coudn't distinguish if their tie rod pkg was any different (dimensionally speaking) form the original.
Any one else experience this problem? I'm gonna probably end up call them up and trying to sort it out but I figured I'd send the question to the real experts here!!!
Here are a couple of pics. The one with my finger is pointing out the groove worn into the inside sidewall. The pics are from my camera phone...
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 10-14-2008, 05:45 PM   #2
prostreeter58
prostreeter58's Avatar
Re: Tie rod setup on my 59 Apache
I think you were spot on when you mentioned decreasing the backspacing.........if you are going to keep the current setup you will need to change the spacing.........
prostreeter58 is offline   Reply With Quote
Old 10-14-2008, 05:57 PM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
Nice to see you on the forum Tex.
Try a wheel spacer.
Maybe a 1/4" or 3/8th" should move it away enough.
How is the little one doing?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-14-2008, 06:17 PM   #4
texascowboy593
I agree about the spacing. I still need to buy a newer tie rod and ends for safety. I even showed him the graphic in the Summit catalog showing how to determine backspacing etc. Thx ProStreeter!
Try a wheel spacer.
I'll run it by Woody (The Mechanic). Glad to be back even if it's only part-time. The world has gone into fast-forward for me and I just don't have the time to post like I used to.
Lil Cooper is doing great. Took him to the doctor for a checkup today. He's 17.5lbs at 5 months old! He's gonna be a big guy like his old man!
Thx E.G.!
1977 Silverado K10
