10-14-2008, 05:19 PM | #1 |
Temp Drip Rail Filler?
PO had filled in the drip rail with something . . . Bondo?
After 5 years in the weather it was cracking. Never liked it and thought it would just hold water rather than channel it off. Well . . . when waxing the cab last week I tore into the rain gutters. Popped out all the bondo junk and most of the original seam sealer. It wasn't bad at all under all that. No rusted through areas at all. Then I used one of the fiber type drill wheels to clean off the surface rust. The plan was to use Eastwood rust converter on it, then coat it with Eastwood Rust encapsulator. I had neither on hand and had to leave for a few days, so I brushed on Rustoleum Heavy Rust primer (reddish brown thick stuff) and the next day sprayed on a top coat of Rustoleum White. I consider all this a temporary repair to keep the rain gutter flowable until I do the Eastwood fix this winter in the garage, or next spring outside. Question is . . . what can I use as an effective seam sealer now, that I can get out again when I get the materials for a permanent fix? Any ideas out there?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
10-14-2008, 07:09 PM | #2 |
Re: Temp Drip Rail Filler?
I have used regular house type caulk
for temporary sealing and it works. I use the non silicone to avoid future paint problems. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-14-2008, 09:09 PM | #3 |
hey lobo, im right over the mountain from ya, post some pics of your truck in case i see ya out sometime. any shows over in your area?
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
10-14-2008, 09:20 PM | #4 |
3M makes some really nice self leveling caulking.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-14-2008, 09:29 PM | #5 |
how bout none
http://i250.photobucket.com/albums/g...y/SANY0219.jpg http://i250.photobucket.com/albums/g...y/SANY0221.jpg
1967 LWB 4speed-current project 1970 LWB 3 speed -stolen 1980 Z28 - sold 1968 Barracuda Big block- sold 1969 Firebird 400/400-sold |
10-15-2008, 09:33 AM | #6 |
va_tlc - Will post pictures later. My avatar is a picture of my truck. White cab, turquoise truck, white bed floor. Not much goes on in Charlottesville with "vintage" vehicles. I bought the truck from a GE engineer in Salem, Va 5 years ago. There was a drive in there that had tons of old school metal on the weekends, but C'ville has nothing going on.
Hart_Rod - I will use a two part self leveling drip rail calk like the 3-M later, after I get the rust converter and encapsulator, but for now I need to fill the bottom of the drip rails to protect against the fall and possibly winter rain and snow until I can clean out the drip rails and do a lasting fix. Hotrodxy - although it looks great, somehow I don't think your solution will help me with my particular situation . . .
