Old 10-14-2008, 09:11 PM   #1
pete29
can i put a 2wd steerin box on 4wd.
I need a different steerin box for my 4x4 72 gmc. will a 2wd one work. what is the difference.
pete29 is offline   Reply With Quote
Old 10-14-2008, 09:18 PM   #2
1972CST
1972CST's Avatar
Re: can i put a 2wd steerin box on 4wd.
I think some guys run a 2wd box for cross over steering but not for a stock application.
1972CST is offline   Reply With Quote
Old 10-14-2008, 10:21 PM   #3
AJs72K5
AJs72K5's Avatar
A 2wd steering box will work in a 4x4. Guys do it all the time to run crossover steering. To run the 2wd box with the stock draglink and steering arm, you'll need to pull the pitman arm off and clock it over 90* to the driver's side to put it into a front to back sweep as opposed to side to side.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 10-15-2008, 07:38 AM   #4
Bentblazer
Bentblazer's Avatar
Getting ready to replace my steering box also, curious what is the advantage of the cross over steering with a 2wd box or is there any?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 10-15-2008, 08:07 AM   #5
pete29
do you use the piman arm from the 4wd or 2wd. If i do clock it over 90* then will it still be long enough. Also will a 73 steerin box work on a 72.
Old 10-15-2008, 08:13 AM   #6
AJs72K5
AJs72K5's Avatar
The 4wd pitman arm will only go on a 4wd box and in only one position due to the key in the splines. The 2wd pitman and sector shaft are just splined...no keys or keyway. You can put it on in any orientation you want.
- AJ
Old 10-15-2008, 08:21 AM   #7
FormerMember
Yes, you can use a later model box on the earlier frames.
Watch the line type. In 81 they switched over from flared hydraulic lines to o-ringed.
FormerMember is offline   Reply With Quote
Old 10-15-2008, 09:30 AM   #8
Burt4x4
Burt4x4's Avatar
Why?
What are you trying to do?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-15-2008, 02:06 PM   #9
pete29
so do i use the 4wd pitman arm, if i use the 2wd it does not have a whole in it to connect to my 4wd drag link.
Old 10-15-2008, 04:37 PM   #10
Burt4x4
Burt4x4's Avatar
Pete, the 2x4 box rotates side to side, the 4x4 box rotates front to back. Yes it will bolt up but two different configs.
Old 10-15-2008, 08:44 PM   #11
Rokcrln
Rokcrln's Avatar
We used to do the cross over steering when we had big lifts and large tires and it really helped. The stock style 4x4 steering runs from the box right to the top of the drivers side knuckle and as you lift the vehicle your pitman arm starts getting a very steep angle even with that C style drop arm. With cross over steering you can keep a more flat steering angle and you will gain a tighter turning radius.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-15-2008, 09:25 PM   #12
drivethechevy
drivethechevy's Avatar
Kevin
LFD Inc.
what all do you need to do cross over steering?, i would like to put a power steering box off of a 68 k10 on my nonpower steering 68 k10
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
