Old 10-15-2008, 12:35 AM   #1
Pont406
Factory oil pressure gauge reading
How accurate is a factory oil pressure gauge compare to aftermarket one in a 69 c10? I like factory gauges but my oil gauge reads weird. Hot oil pressure at 800rpm in gear is 3/4 reading. Anything over 2200 rpm and a needle is slightlly over the H. All readings after driving for 30-40 min and 180 temp. Is 3/4 reading 30psi or so? Thanks
Pont406 is offline   Reply With Quote
Old 10-15-2008, 04:19 AM   #2
JimKshortstep4x4
Re: Factory oil pressure gauge reading
I have a master gauge that I have compared the factory gauges to and the readings have been close. Your 69 probably has a 60 psi gauge in it so a 3/4 reading would be approximately 45 psi.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-15-2008, 06:33 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Jim
Thanks for sharing that info! You usually have people say stock gauges aren't accurate. The only truth to that statement is they don't have anything to compare them to. Since you've compared to a couple of gages with same results thats good enough for me!
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
