10-15-2008, 02:07 PM | #1 |
Fire wall smoothing
I will be smoothing my entire firewall pretty soon and i wanted to know how are people smoothing the channel on top of the fire wall i know it usually is a good spot to run wires across the top of the firewall, but i have seen it done. For example on project sweet pea which is (bad6772) that guys firewall is beautiful, I am just wondering if any other people have done it. I already ordered the filler panels for heater and ac on the firewall, but do i just need to fabricate like a 1 inch strip of metal and weld it from one side to the other....thanks for any help guys
http://67-72chevytrucks.com/vboard/s...=253584&page=5 that is a link which has his good looking firewall all smooth |
10-15-2008, 05:58 PM | #2 |
Re: Fire wall smoothing
My firewall is completely smoothe but I did not take that lip off the top....I should of thou...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 10-15-2008 at 08:37 PM. |
10-15-2008, 06:14 PM | #3 | |
The hardest part for me was the corner where the fan blower motor was. It was a PITA to keep the metal @ the same level as the original firewall (it wanted to bow toward the cab).
10-15-2008, 07:12 PM | #4 |
yelp, it was about 1.125, but make it just a tad langer and grind to where it needs to be.
10-15-2008, 07:24 PM | #5 |
When you shave it , I would "CAP" the passenger side of the firewall so it matches the drivers side. As you can see I didn't do that to mine, and now I wish I would have.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
10-15-2008, 07:39 PM | #6 |
thanks guys for yalls input...i appreciate the advice...i have noticed the slight difference in firewalls as well my truck was factory ac and i can see the difference on the passenger side...that blue truck looks good up there...i prolly wont "cap" the passenger side though. Thanks guys
10-15-2008, 07:58 PM | #7 |
sharp as a marble
I was wondering if any one had moved the firewall forward, towards the radiator. I have been looking for a way to increase the leg room in my 69, and wondered how hard it would be to grind all of the spot welds near the lip around the firewall and move it forward a couple of inches. Kind of a modern cab forward, kind of deal. If you smoothed and moved the firewall forward a couple of inches it would creat a bunch of leg room, and no one would know until you popped the hood
10-15-2008, 10:05 PM | #8 |
MY EX DRIVES A BROOM
If I get off early tomorrow I will try to get some pics of mine, showing how I routed my wires.
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
10-15-2008, 11:19 PM | #9 |
Chevy Truck Addict
Here's mine... We cut the lip off, and welded the metal back together along the seam. Then, it was built out on the passenger side to match the driver's.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
10-15-2008, 11:50 PM | #10 |
Here's a few picks of mine prior to paint. I just picked the bed and cab up today so I'll post some painted pictures soon.
10-16-2008, 05:32 AM | #11 |
I would like to see some pics of the wire routing . I have mine shaved but not the fuse box connector , like some I have seen . I will get some pics up so yall can give me some ideas on what else to take off
My ZipCode = 29673 2008 Silverado Z71 LTZ Wrecked New Ride SOLD 71-72 Custom A/C Parts Truck < selling parts 67 Chevy ShortStep SOLD 67 GMC SWB Step <-- For Sell 67 Chevy SWB Step <-- working on 2000 Road King <-- SOLD 97 F150 my ride for now 2006 Escape wifes ride HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669 Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2 |
10-16-2008, 10:29 AM | #12 |
This seems like a much simpler approach to "smoothing" the channel.
10-16-2008, 10:35 AM | #13 |
Chevy Truck Addict
My bodyman suggested it and I thought it was a good idea... It turned out great and, as you said, it was pretty straightforward - A lot less fabrication and messing around.
10-16-2008, 11:08 AM | #14 |
That's how I did mine.
10-16-2008, 11:38 AM | #15 |
Farm Truck
Those look sweet.
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
10-19-2008, 09:01 PM | #16 |
here are a few progress pics of my firewall.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
10-19-2008, 10:37 PM | #17 |
THIS is a smooth firewall!!!
10-19-2008, 10:49 PM | #18 |
WOW!! I do believe that is the definition of SMOOTH! Remarkable.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-20-2008, 10:23 PM | #19 |
here's mine
10-21-2008, 04:48 AM | #20 |
those are smooothhh . I like the look of them . mine aint that smooth but I want to know about the wiring . no hole for fuse box connector on mine either . like how are you going to wire under hood ? keeping an eye on this thread
My ZipCode = 29673 2008 Silverado Z71 LTZ Wrecked New Ride SOLD 71-72 Custom A/C Parts Truck < selling parts 67 Chevy ShortStep SOLD 67 GMC SWB Step <-- For Sell 67 Chevy SWB Step <-- working on 2000 Road King <-- SOLD 97 F150 my ride for now 2006 Escape wifes ride HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669 Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2 Last edited by tommypic; 10-21-2008 at 05:16 AM. |
10-21-2008, 05:11 AM | #21 |
Official Site Guitar Shredder
Here is mine.....Its alot further along than these pics. But gives you a general idea..
10-21-2008, 11:16 PM | #22 |
My firewall after paint.
10-22-2008, 10:48 PM | #23 |
nwd02- is that a 4.3l serpentine setup?
10-22-2008, 11:06 PM | #24 |
It's a 5.7 off a 94 chevrolet truck. I haven't turned it over yet but the belt fits really nice. There's actually a guy selling one on ebay for like $200. I picked mine up for $100 then sand blasted the brackets and pulleys. The alt, a/c compressor and p/s pump all 94 chevy truck. I had to modify the p/s pump to accept the high pressure hose fitting for the older flange.
When it comes to wiring I'm considering bringing the wiring out of the cab over the tranny, then down the side of the motor. The lighting wire I'll run across the crossmember and around to the grille. All motor wires will either come up the back of the block or up the front (compressor and alt). At least this is tonights plan, but things change... haha. I'm replacing all wiring with the Ron Francis Express kit. There's actually a group buy going on through Mike's Bump and Grind Garage. He's a member on the forum but time is running out on the buy. http://67-72chevytrucks.com/vboard/s...d.php?t=309661 I'm planning on using high pressure braided lines for my brake line connecting to the master cyl. my hard lines are ran on the frame, directly under the front of the cab. The soft lines will connect there and then continue. |
10-22-2008, 11:30 PM | #25 |
what are you guys using for a heater?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
