10-15-2008, 03:09 PM | #1 |
84' to 89' Face Lift....
If I were to do the face lift like to an 89' Suburban, what will I need to change? I'm tracking that I'll need the grille, headlight doors, and headlights. But I was wondering if I could get some clarification into whether or not I would need a new radiator support, wiring harness, fenders, hood etc. Also, if I were to try and make my crew have p/w, p/l how do we do that also? Thanks.
10-15-2008, 05:25 PM | #2 |
Dually Pride
Re: 84' to 89' Face Lift....
yes you need a radiator support and i dont believe you need to change the fenders and hood. the wiring can be modified easy enough
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
10-15-2008, 06:33 PM | #3 |
How hard is it t swap out the radiator support? Is it just a matter or loosening and tightening some bolts or is it more along the lines of hacking and welding???
10-15-2008, 06:43 PM | #4 |
I don't think these pills work
all bolts
SQUARE84 90 SUBURBAN |
10-15-2008, 06:45 PM | #5 |
www.73-87chevytrucks.com
unbolt all the bolts to the support, unbolt the 2 radiator mounts loosen the fenders and pull it out. It isn't a cake walk getting the new on in, but it can be done. GMChemist did this to his.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-16-2008, 01:25 AM | #6 |
Sounds great, Thanks!!!
10-16-2008, 02:11 AM | #7 |
1 more thing, does anyone have pictures or know of a walk-through that shows all the steps.
10-16-2008, 11:35 AM | #8 |
Wide n'Low
I was going to do the same thing, and aquired all the parts. Mine was going from a 78 to an 89, and for anyone interested in doing a conversion like that you will also need the wiper transmission assy. as it has longer shafts for the wiper arms to connect to. It will require drilling a new mounting hole. You will also need the plastic apron that goes below the windshield as the 73-80 style hood is different than the 81 and newer.
Lastly, for the early conversion, you will need to locate and drill a hole on top of the firewall to properly mount the fenders, I think the article below shows that in detail. There is an article here that shows most of what you need to consider http://coloradok5.com/grilleswap.shtml It's not hard at all, just take your time. As for the headlight wiring, if you don't have it, you can use either the factory one from a 89-91 Blazer or Suburban, or the same one is used by the van's that have the 4 light setup.. Hope it helps, Drew Run down on parts for a 73-80 to a 89 Burb conversion.
That is most of it I think..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
10-16-2008, 12:03 PM | #9 |
This from Gchemist (that I referenced above) It is from a 83 to 89-91
http://www.geocities.com/abetterchem...rillchnge.html
