10-15-2008, 04:45 PM | #1 |
Im bummed
Im bummed i just decoded the engine block numbers on my 70C10 and i thought i had a 350. Well it isnt the code is 355909 witch is a 1975-1983 305. Now i need to get a 350 to replace that 305 that just made my day.
http://67-72chevytrucks.com/vboard/a....php?f=50&a=17
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... Last edited by Longhorn Man; 10-15-2008 at 06:44 PM. |
10-15-2008, 05:45 PM | #2 |
Re: Im bummed
Hey man if you were happy with it before just leave it alone especially if it already runs good not much of an upgrade unless you just want to go with a rebuilt
10-15-2008, 05:51 PM | #3 |
Green club
Re: Im bummed
I feel your pain, I thought mine may have been a 350 as well, but turned out to be a 305.
On the positive side, it's very durable, reliable and does not smoke at all just down on power a little bit compared to the average Camry . So, if you just want a 350, consider sticking with the little 305 until you can afford an engine that you really would like.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
10-15-2008, 05:55 PM | #4 |
MOVE OVER
Re: Im bummed
could be worse,, mine turned out to be a 307...
No matter where you are..... There you are... Buckaroo Banzi |
10-15-2008, 07:28 PM | #5 | |
Re: Im bummed
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
10-15-2008, 08:46 PM | #6 |
Re: Im bummed
The same exact thing that happenned to me!!!! I definetly know how dissapointed I was with a 307 and a 3speed manual truck!!!!! MAIN REASON why I just spent a ton of $$$$$ on the bucket...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-15-2008, 09:17 PM | #7 |
20' Daredevil (Ret)
Re: Im bummed
10-15-2008, 09:18 PM | #8 |
Re: Im bummed
look on the bright side now you can go for a big block
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
10-16-2008, 07:13 AM | #9 |
Re: Im bummed
Don`t worry about it.It`s just a bunch of numbers.What`s the problem?Were you trying to figure why it wasn`t running better and discovered it was a 305?Or,was everything fine until you ran the number?I`d be happy with a 194 if it got my truck down the road well enough to not know what was under there.You stand a better chance at optimum fuel economy with the smaller displacement.
There`s nothing wrong with the 307 either.Prolly one of the most under-rated small blocks out there.Many got pulled and tossed just to have a 350 with half a handful more horsepower.Many of the ones that stayed in are still powering these trucks.GM never based a performance motor on it because back them it was all about going bigger and the 307 was the economy V8.The 305 never would have seen an H.O. application if it wasn`t in use during the Downsize era.It`s certainly no better motor than a 307.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-16-2008 at 11:22 AM. |
10-16-2008, 07:50 AM | #10 |
Re: Im bummed
I would much rather have a 307 than a 305. The 307 has a better bore to stroke ratio than the 305. The 307 is basically a 283 block with a 327 crank. You can safely bore the blocks .100 over and have a 323 ci engine.
The weak link in the 305 is the very undersized bore(3.785). It's wht helps it in the gas mileage dept. though. 70chevyc10, if your just driving it, there's nothing bad about a 305. If you're wanting more hp, well, I understand your disappointment.
10-16-2008, 08:43 AM | #11 |
Re: Im bummed
I actually wish I had left the 250 I-6 in my truck...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-16-2008, 09:47 AM | #12 |
Re: Im bummed
I think about that alot too. My parts truck, I was told was a 350, but it turned out to be a 305. It ran real strong until the rod bearing gave out, so as other have said if it runs good and you were OK with it until you ran the numbers, then I would run withit until you get the funds to do the engine the way you want it to, including buying a new one if that is what you want.
10-16-2008, 11:14 AM | #13 |
Skinned knuckles
Re: Im bummed
The 60 Chevy truck I bought when I was 18 was supposed to have a 327 in it, but I later found out it was a 262 out of a Monza.. It didn't lose any power once I found out, but it didn't feel as "cool" either...
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
10-17-2008, 10:16 AM | #14 |
Re: Im bummed
I felt that way a few times, especially at the gas pumps, but I get over it as soon as I mash the GO-Pedal.
I would actually like to buy a beater truck with a 250 in it just to have.
10-17-2008, 01:30 PM | #15 |
Re: Im bummed
Me too.If anything,I`d add o/d.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-17-2008 at 01:33 PM. |
10-17-2008, 01:42 PM | #16 |
Certified BFH Operator
Re: Im bummed
DOn't feel bad if it runs good. I had a 305 (non-original) in my 69 swb for almost 2 years, it wasn't bad, just not quite as peppy as a 50 would be. it finally gave out mothers day weekend the number 7 rod decided he wasn't going to my mothers house with me, so it left me and took a piece of block casting with it as a hostage. FInd you a nice block and build it til your content, and swap them one weekend. enjoy the mpg!!
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
10-18-2008, 12:06 AM | #17 | |
Local Detroit diesel nut!
Re: Im bummed
My opinion on the 305, if it runs and drives and get's the job done, leave it in there and tell everyone it is a 350. Nobody will be able to tell while looking at it!!! The 305's were good motors, just they were overshadowed by the 350!!! Good luck! Mike
Nothing cool anymore, I am old and boring.... |
10-18-2008, 05:42 AM | #18 |
Re: Im bummed
As I said before I was dissapointed with my 307 it had no balls and it felt like a four banger, sold the complete powertrain back to the guy I bought the truck from he is using it in an older impala or something he said then I buil me a small block 400 with all the bells and whistles and the thing feels like getting hit with a 2x4 accross your back when you step on it.....I could not be happier with the motor so far, I am having a leak issue with my tranny but that is a complete different situation...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 10-18-2008 at 05:44 AM. |
10-18-2008, 05:50 AM | #19 |
The LuvShack Garage
Re: Im bummed
I had a 67 SWB Big back window sold to me with a 327/Powerglide
combo only to find out the 327 had been pulled and it was a 283.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-18-2008, 07:28 AM | #20 |
Re: Im bummed
Don`t you wonder what a 307 would run like with all the bells and whistles?Sure,not like a 400.But,you may be surprised.Really,when does anyone see a built-up 307?The trend has always been to go bigger,naturally.And,I like a big motor.But,with things changing I`d like to see how small a motor I can get enough power from and get best mileage.A new approach to performance that involves not necessarily going fast,just strong.But,pretty fast if you want.
10-18-2008, 08:04 AM | #21 |
Re: Im bummed
I know the feeling. IMNSHO 305's make thge best boat anchors money can buy. I have had two of them and both tanked between 90k & 100k....both had lower knocking problems.
There's a reason you don't see too many 307's built up and it's the same reason there's not a lot of 305's out there. Sure there's a few and there's always going to be a few who swear by them, but for the most part they are hard to find. There's very little a 305 or 307 can do that a 327 or 350 can't do much better.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
10-18-2008, 08:21 AM | #22 |
Re: Im bummed
Hell im actually the opissite..I blew the 350 to peices and am swapping in a 327 turbofire
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
10-18-2008, 02:55 PM | #23 |
Re: Im bummed
my truck had a 305 in it when I got it. PO also cut open a heater box to replace a blown up heater core. I took 305 to work and gave it to a scrap man.
10-19-2008, 04:05 PM | #24 |
Burnouts are therapeutic
Re: Im bummed
this is why I never buy a truck or car without first running the numbers ,an old car with a 305 or 307 doesn't have the value of one with a 350 . 327 or 400 I went to look at a 71 longbed 2 weeks ago for a donor guy said it had a 350 ran the numbers and it was a 305 it was a good running truck , but try selling a truck for $15,000 with a 305 in it (thinking of my current project)
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
10-19-2008, 04:08 PM | #25 |
Why does it taste purple?
Re: Im bummed
I had the same thing happen to me when I bought a El Camino.The old guy said it was a 350 but there was so much grease on the engine I couldnt see anything.I found out it was a 305 when I went to do a intake swap.Man was I pissed.It was like the end of the world to me.I called the junkyard the next day and came home with a running 86 350 for a cool 400 bucks.
Lesson is never buy a vehicle without running numbers |
