![]() Join Date: Aug 2008
64-66 4x4 Brakes
Can anyone tell me about the brakes available for the early 60's 4x4 trucks? When were disks versus drums available up front? What would be the options for swaps to put disks up front?
I'm inheriting a 69 pickup from my dad that actually sits on an early 64-66 frame. It has power steering and disk brake in the front.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Re: 64-66 4x4 Brakes
60-66 4x4s (2WDs too) are all drum brakes. 71 and up are disks up front. The easiest way to switch to disks is to swap in a later Spicer 44 (10-bolts fit too), you'll probably want to switch to power brakes at the same time.
How is the power steering mounted on your 69? Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
well what the PO did was weld some 67-72 cab and radiator support mount brackets onto the 66 (I'll just call it a 66 for now since i don't know the exact year) frame.
he also welded a 1/2" steel plate to the outside of the frame where the steering box mounts, and put the power steering in. it has power brakes, disk up front, drums in the rear, but i haven't inspected it too much yet. Don't know what front axle its got in it. also, he welded in the 4-speed tranny crossmember. but it has the stock np208 transfer case. what other transmissions would have/could have come in these trucks?
SM-420/Rockwell 221
SM-465/Rockwell 221 SM-465/NP-205 TH-350/NP-205 Also some three speeds and the Spicer 20 T-case but I'm not up to speed on what possible combos you get out of those. 73-87 gets even more complicated. Bob
If its a 60's or 70's anything, that NP208 is not original. That didn't happen until the 80's. It sounds like you may have a frankentruck on your hands.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Whoa, I don't know what I was thinking when i typed np208, haha!
The truck currently has a 350 + SM420 +T221 in it. However the transmission cross member looks like it was welded in. Which leads me to believe maybe the at some point it had a different transmission. So on of my questions is: which motor + trans + transfer case combinations would have been available in a 66 or earlier truck? I didn't think that anything but a sm420 would be able to fit in with where the t221 is located. I suppose it doesn't matter too much at this point, though I wish the PO had bolted the cross member in rather than welding it. But it is still mysterious.
