reproduction steel doors or fiberglass?
I am having trouble finding a set of good oem doors. From southeast missouri and everything around here is rusted out. Would be willing to drive for a good set though. Just wondering if anyone has used the repo steel or fiberglass doors. Curious if they fit well or not. Thanks for any input.
#2 | |
1 thing at a time is progress.
Re: reproduction steel doors or fiberglass?
![]() They are a little wavy. ![]()
Alan
Philippians 2:14-16 |
Registered Asphalt Offender
Yep, the Goodmark doors will require a little tweaking like Alan showed you but that goes for any aftermarket sheet metal. They are high quality parts though. I would always go steel if it's available. Unless you are building a racer and need it to be light weight.
![]() ![]() 1963 C10 Short Fleetside Bed Big Back Glass 1974 C10 Short Stepside Bed 1982 S10 Shortbed 350 EFI V8 http://67-72chevytrucks.com/vboard/a...hp?albumid=140 http://www.hubgarage.com/mygarage/MEANlowGREEN http://www.motortopia.com/garage/cars/MEANlowGREEN http://www.myspace.com/jcsmeed |
Personally I would go thru the heartache of rebuilding the originals over another set of Goodmarks. There are definite differences/flaws compared to the originals. I got them to work, but..........Maybe I'm just too fussy.
![]() Last edited by skidder111; 10-16-2008 at 11:20 AM. |
I know the 67-72 Goodmark doors have alot of issues. Two coworkers replaced both of their doors on both trucks and had alot of problems.
Alan
good lookin cab. I see you have shaved the drip rails on the posts, is this why you had to add the piece to the door?
I thought that was the cause, but the passenger side lined up pretty good.
Alan
Resistance is Futile
A little off topic, but here goes anyway. I bought a re-pop fender for my pick-up and thought it sucked. I took out the piece from behind the grill and replaced it w/ the original and figured I had about 3 hours work on a 'new' piece of sheetmetal. I just picked up a fender for my 'burb that is good but has some dents and needs the typical lower patch. I think I can get it done in a few hours time, improve my skills, and come out at least 100 bucks ahead of the re-pop fender. Luckily there are tons of good parts here in AZ.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
The 64-66 doors fit better than the 67-72 and Goodmark quit selling them. We also do not sell the 67-72 doors currently. We have not had too much trouble with the 64-66 repro doors. Even the stock doors from truck to truck are not perfect fits. I went through 4 oem doors on the drivers side door and never really found one that did not leave a large gap on the A pillar. I the passenger sides was fine.
