Old 10-16-2008, 10:09 AM   #1
drummin89
drummin89's Avatar
mix and match
Im planning on converting to power brakes and mounting it on the firewall, but am unsure how to go about this. I bought a pedal assembly, booster and master cylinder out of a mid 80's suburban from a junkyard for about $20, with the plan that I would modify the pedal assembly to work on my 52 Chevy 3/4 ton pickup. Im now thinking for ease of installation and looks that I will go with a premade/fabed setup from CPP (or any other if anyone has suggestions!). Here is the thing, since I already have a booster and master cylinder, is it possible that I could just buy the pedal assembly from CPP and mount the booster and master cylinder from the suburban to it? Or what other booser will mount up to the CPP pedal assembly that the suburban master cylinder will bolt to. The booster and master cylinder seemto be new and to have been recently put on the truck before it went to the junkyard so Id like to use what I already have.
The reason for the switch/want to use the CPP assembly is because I still have the stock mechanical clutch & pedal and a throttle cable type gas pedal in place of the stock one, and the suburban pedal assembly would put the brake pedal right on the clutch pedal, and would need a bit of modifications to make it so its in the stock location.
http://www.classicperform.com/Store/...s/4753FBBD.htm
here is the tread I started about using a 80's suburban pedal assembly
http://67-72chevytrucks.com/vboard/s...pedal+assembly
I may try calling CPP but I wanted to see if anyone had an idea or a way to go about this.
Thanks!
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 10-16-2008, 04:24 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: mix and match
they do sell it seperately but calling them is best.
dwcsr is offline   Reply With Quote
Old 10-16-2008, 06:16 PM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
Re: mix and match
I'd check on the dia. of the booster as well. Think the kits use a smaller dia one.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-16-2008, 08:49 PM   #4
drummin89
drummin89's Avatar
Re: mix and match
the diameter of the booster in the kits is 8in.
Im also going to check on something at the junkyard this weekend. I already got something off of this truck that matches up perfectly with the 52 dash. I wont tell what until I know if it will work but unfortunately I must say its from a..a..a...f....o....r...d
Chris
