SBC Chevy High Performance Engine
$3000 - 010 casting 4-bolt block / .030 = 355ci
- GM forged steel crank - GM X Rods - Flat top forged Pistons - Competition Cams solid Roller Camshaft 274XE - 1.6 roller rockers - AFR 195cc aluminum cylinder heads - Double roller timing chain - HV oil pump - 7qt zinc plated deep sump pan - Reinforced zinc plated timing cover with button for roller cam - Head studs - Felpro gaskets - Edelbrock Performer RPM intake - Full ARP black oxide bolt kit - Fabricated aluminum valve covers All fresh and ready to go - was built to match a proven build recipe - should be solid 450-475 horsepower with good carb and ignition system. ![]() ![]() ![]()
72' LWB Cheyenne 73' Camaro Z28/RS 70' Chevelle RagTop 00=ss=00 Last edited by Rreemo; 09-13-2012 at 03:54 AM. |
Re: SBC Chevy High Performance Engine
Are those the new AFR eliminator heads? If so thats a good deal considering the heads and valvetrain are worth over $2k alone.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
