10-16-2008, 08:20 PM | #1 |
Duramax Swap?
I'm a newbie and glad to be a member of this site! I will post some pics and edit my profile soon. In the meantime...
I just bought a 71 Chevy Suburban. I am going to restore it from the ground up - at least that's my plan. I was wondering if anyone has heard of dropping a Duramax-Allison-Transfer Case into this truck? Is this even reasonably possible? If so, do I need to box the frame? Any suggestions would be welcomed as I'm new to this process, but willing to learn. My brother, who's done many restores, is involved too. I wanted to check here before I spring my plans onto him. |
10-16-2008, 10:07 PM | #2 |
Re: Duramax Swap?
Welcome! Anything is possible and a Duramax would be cool, but........, I think you would have to beef up the frame and suspension quite a bit because the weight of the Duramax (take a look at the factory Duramax chassis sometime, it is Ginormous!). A lot of guys use the older dodge diesels for this conversion because of the reduced weight. It might be worth waiting until GM comes out with their smaller diesel, I think it will be more practical. Just my 2 cents. Take care.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-06-2009 at 01:28 PM. |
10-16-2008, 10:16 PM | #3 |
its all about the +6 inches
Re: Duramax Swap?
What are you looking to get out of the engine swap, more power, more MPG, or the neat factor?
10-16-2008, 11:51 PM | #4 |
Re: Duramax Swap?
I dont know that I have ever seen a Duramax swap, only the Cummins. And lets face it, the Duramax would be way more badass than a Dodge motor
10-17-2008, 02:27 AM | #5 |
Re: Duramax Swap?
there was a chevy step side not long ago in diesel power mag it was way cool. This big problem with this swap is the wiring and electronics its crazy complicated somthing with the ECM and the dash working as one I wold go to thedieselplace.com and serch there they have a lot of infor on it.
Earl 68 2500 4x4 GMC Burb |
10-17-2008, 12:07 PM | #6 |
Re: Duramax Swap?
I've seen other swaps done with the Cummins. Don't get me wrong, the Cummins is a nice motor! But wouldn't it be awesome to put the Duramax in? Obviously, I'd get the horse power, mpg, and WOW factor!
Really, I was just wondering if it could be done without too many problems. I like the diesels for many reasons - longevity being one. However, if it is going to be too difficult or too expensive to do, I will pass. Is the Cummins swap any different - easier? |
10-17-2008, 01:02 PM | #7 |
Re: Duramax Swap?
Depends on what your definition is of expensive....
I'd expect a minimum of $5K with a high-mileage duramax motor and you doing all the work.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
10-17-2008, 01:20 PM | #8 |
Fix It Till It's Broke
Re: Duramax Swap?
pick up this months truckin mag the ufc fighter Matt Hughes had it done in his 66 SWB and they to an 06 chassis/motor/Tranny and swapped the body onto it. Maybe look at one of the 90s burbs that had the 6.5 turbo diesel and see about doing it that way. Just my 2 cents
Tony Black Beauty: 85 C-10 SOLD! Great White: 69 LWB Custom Camper/20 SOLD! Blue Dragon: 72 K-10 SOLD! The Tank 77 K-10 KIA panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for. I Made The Official So Cal Board Meet |
10-17-2008, 02:19 PM | #9 | |
Re: Duramax Swap?
http://67-72chevytrucks.com/vboard/s...d.php?t=303017 4 Door Crew cab: http://67-72chevytrucks.com/vboard/s...d.php?t=309911 I had thought about putting a Duramax in my 4 Door CrewCab, but I had already built a 1/2 Ton frame and didn't want to start all over again. At least ......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-17-2008, 09:05 PM | #10 |
Re: Duramax Swap?
Everyone: thanks for your responses. I will table this matter for now as I have body work, interior, and lift/tires to address first. It has a running 350 with a turbo 350 tranny (I'm told), not sure what the transfer case is.
Plan to confirm tranny and transfer case this weekend. Thanks again, I'm sure I'll be asking more questions later. It's nice to have other's, who've been through this before, to pick their brains. |
10-18-2008, 10:42 PM | #11 |
Re: Duramax Swap?
I am in the process of puting a 68 burb on a 2004 duramax chassis. I changed the wheel base and am getting ready to build body mounts
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro |
10-20-2008, 08:09 PM | #12 |
Re: Duramax Swap?
LBZ, LB7, LLM, LLY?
I have a duramax, a 04 crewcab 4x4. Its pretty cool, but I don't know if I would put too much effort into swapping it into something. The allsion needs to be beefed up before you can squeeze any enjoyable horsepower out of one, or it will just go in limp mode. $3000 if you do the work. Each duramax has its own set of problems, be it LB7 injectors, LLY overheating, LLM oil leaks/consumption, etc. They aren't all that heavy, as they are all aluminum, but with the extra torque the frame would have to be boxed. things to ponder.. |
11-01-2008, 09:06 PM | #13 | |
Re: Duramax Swap?
'72 Super Custom Suburban - 402/400, original bucket seats, 3rd seat, rear air, tilt A few Yenko cars Interested in COPOs, Yenkos or other dealer built muscle cars then go here:www.yenko.net |
01-29-2009, 04:56 PM | #14 |
Re: Duramax Swap?
I Love Duramax's almost as much as my classic Chevy's.....I thought it would be a sweet combo and have looked around and it seem pretty pricey to swap one into a frame of a 67-72.... My question/idea is why not take a regular cab long bed 3/4 ton pickup with a duramax/allison in it and shorten the frame? I am not so sure it would work but I thought it would solve the electrical problems encountered as well as suspension strength and moving those cross members around.
1970 Chevy X 2 2002 Chevy 1500HD 1990 Dodge Ram 50 (Gas Gitter) |
01-29-2009, 11:10 PM | #15 |
Re: Duramax Swap?
heres a thread on one:http://67-72chevytrucks.com/vboard/s...d.php?t=325036
