A new C10 Addict!
Blazer tank swap
I thought I read somewhere you can use the Blazer gas tank to get rid of the tank behind seat in the cab. I think it said you pretty much drop it in the rear of the bed between the frame rails and bolt in down and run new lines. Now I can't find the post anyone have a link or a here's what you need list?
Thanks LeDevil ![]() |
DON'T TREAD ON ME
![]() Join Date: May 2005
Re: Blazer tank swap
There are several threads over in the FAQ section. http://67-72chevytrucks.com/vboard/f...aysprune=&f=92
Old Yeller |
A new C10 Addict!
Haha.... I have got to be dumb I didn't even re check in the FAQ section thank you.
Mods if you want you can delete this post |
![]() Join Date: Feb 2001
Do yourself a favor and lay down under the back of a Blazer and study it and your truck. It's not as easy as dropping it in. You will have issues you need to think about before you tackle this.
This may be one of the better mods done to our trucks. There is a lot of info there on this modification. Last edited by Mudder; 10-17-2008 at 12:08 AM. |
