10-17-2008, 12:36 AM | #1 |
"THE GREEN GOBLIN"
Help Decode my motor & Heads!
The numbers on the block are #14015445 last number is a 5 or a 6 is it a 2 bolt or a 4 bolt how can I tell?
The heads seem alittle wierd to me two different numbers is that how it is supose to be? Passanger side is Markings on it GM3T E24\76 #346236 Driver side is Markings on it 346\ CFO or CFD #14081045 Oh and by the anyone know if my intakemanafold is a good one it is a Weiand #7544?
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
10-17-2008, 12:48 AM | #2 |
BlahBlahBlah
Re: Help Decode my motor & Heads!
10-20-2008, 12:08 AM | #3 |
"THE GREEN GOBLIN"
The heads Have two different numbers is that how it is supose to be? I checked my numbers with http://www.mortec.com
Passanger side is Markings on it GM3T E24\76 #346236 This is what I came up with... Mortec Site read the following= 75-87...OVAL...OPEN...454,120cc Chamber,225/116cc Ports Driver side is Markings on it 346\ CFO or CFD #14081045 And Mortec Site read the following= 78-87...OVAL...OPEN...454 Are these any good I mean the motor runs fine could they cause the motor damage in the long run because they are different in Numbers?
Petey-pablo
10-20-2008, 12:23 AM | #4 |
Only way to tell is to open it up and count the bolts in the main caps...seems they never coded 2 or 4 bolts from the outside.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
