Old 05-10-2002, 09:40 PM   #1
Kas68c10
Kas68c10's Avatar
Post Rear trailer arms
In the process of changing my trailer arms and springs. Took them off today and noticed the brackets welded to the axle that hold the u bolts are rotted and split. Can I buy them, or can a welding shop fabricate them ?
1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 05-11-2002, 12:44 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Post
I just looked at the LMC catalog that came today. If you are talking about the piece that is like and upsidedown spring perch and has a hole on either side. I think it is part of the axle. You might find a junk donor axle and get by cheaper than a welding shop. A core should be pretty cheap.
Good luck
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
Old 05-11-2002, 11:17 AM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
common problem, especially on leaf axles 67-72 also,. all was fixed in 73 with better design of perches.
early classics, etc has the perches, dunno if they would sell them separately or not though.
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
