Old 10-17-2008, 02:54 PM   #1
BarryB
BarryB's Avatar
Can a 2wd tranny be made to fit a 4wd??
I heard this awhile back ago. and if it has been asked before apologize for not searching. I have a 84 Chevy 4wd, Th350. The trans is weak. I have good 350 2wd. I had heard you could remove the back piece off the tranny and cut the shaft down in order to fit the transfer case. Is that true?? Has anybody done it?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-17-2008, 06:40 PM   #2
duallyjams
duallyjams's Avatar
Re: Can a 2wd tranny be made to fit a 4wd??
You would have ti disassemble the 4x4 trans to use the shaft so why not just rebuild it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-17-2008, 07:47 PM   #3
LONGHAIR
It is not as simple as "cutting off" the longer (2 wheel drive) output shaft. The splined section is only at the end, if you could cut it short enough, the splines would be gone. The output shaft is the last part to be taken out of the case....at total rebuild is in order.
LONGHAIR is offline   Reply With Quote
Old 10-17-2008, 10:39 PM   #4
FormerMember
Or you could build a spacer that goes between the transfer case adapter and the transmission housing, this would take up the extra spline on the output shaft.
I've seen that done, but you would need to shorten your rear drive-shaft and lengthen the front one.
FormerMember is offline   Reply With Quote
Old 10-18-2008, 11:05 AM   #5
BarryB
BarryB's Avatar
Thanks guys for the info. I will forget the first idea. I am not againist rebuilding a trans, just thought I'd ask.
Two rules in life.
