Old 10-17-2008, 02:57 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Pain in the ass squeek.
I want to find out how to fix this squeek, it's not the brakes,
When I get on the gas with about 1000-2000 RPMs it squeeks terribly, the belts don't appear to be worn or frayed. But if I get the RPMs up above 2000 it doesn't squeek.
It's a 79 K10 with a Np203 T-case, TH350 Tranny 350 4bbl Carb, if you need anything else just ask.
Benelli is offline   Reply With Quote
Old 10-17-2008, 04:06 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Pain in the ass squeek.
check belt tension by pushing the alternator pulley fan blades by hand with the engine STOPPED. The blades/pulley should not move without the belt moving.
Also check pulley alignment...
Old 10-17-2008, 07:01 PM   #3
Square84
I don't think these pills work
Square84's Avatar
mine did it cause the timing was off. only under acceleration once it shifted and the load was off the motor it quit sqeakin.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 10-17-2008, 07:32 PM   #4
blu87
blu87's Avatar
Spray a little water on the belts at those rpms and see if they quiet down....should pinpoint or elimnate one or more belts.
Gene
blu87 is offline   Reply With Quote
Old 10-17-2008, 11:39 PM   #5
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Benelli: Had the same exact problem and it turned out to be the A/C compressor belt. Hope this helps...
78 Big10 454 is offline   Reply With Quote
Old 10-17-2008, 11:45 PM   #6
78 Chevyrado
quickest thing to quiet a belt down to check if it's squeaking is to put a little DAWN dish soap on it. It doesn't last too long but will let you know in a second if it's the belt or not
78 Chevyrado is offline   Reply With Quote
Old 10-17-2008, 11:48 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
before we narrow it down to a belt.. i need to ask does it do this only when the truck is in gear or in motion ? or does it do it in park too?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-18-2008, 12:13 AM   #8
Benelli
Benelli's Avatar
First off, Thankyou for all the replies.
I would like to add that it usually doesn't do it until 15 minutes or so into the drive, and it usually starts up after a tight corner, and it gets worse going through/out of a turn also.
It does it while in park, or at a stop while in Drive.
Hm. I might have to try that.
Don't have the AC, thankyou though.
I'll try that.
I set the timing about 3 weeks ago, it doesn't feel like it is off.
I can move the blade when I turn it.
How could I go about checking pulley alignment, I'm sorry, I'm pretty new to all of this guys.
Old 10-18-2008, 12:48 AM   #9
Corts60
Just here to tinker
Corts60's Avatar
If you can move the blade by hand, it needs to be tightened. There are two bolts. The upper is usually a 1/2 and the lower is usually a 9/16. You'll notice a hole in the upper alternator bracket, that is where you can stick something with a long handle in to hold the alternator while retightening the bolts...Not too tight though, that could cause premature wear on the bearings inside the alternator. Just tight enough that you can't move the blades by hand. Let us know if that fixes it...
Old 10-18-2008, 06:04 AM   #10
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Pain in the ass squeek.
It sounds to me like the PS pump may be your problem if this is happening only while you are turning the pump my need servicing with fliud or the belts could need adjusting or the pump could be going bad internally and placing extra friction on the belt if the pump pully isnt turning freely.
I dont know how your truck is set up but on mine the PS pump pully has 2 belts so one may be adj correctly and the other one may be lose and it would still squeek.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 10-18-2008, 10:26 AM   #11
old Rusty C10
when you do the water or dawn trick try doing the ps belt first and see if it goes away i agree its prolly the ps belt id look to make sure there is proper level of fluid and there is no fluid on the belts too giving it a little slip when hot
Bob
I hate cancer!!
