Old 10-17-2008, 03:16 PM   #1
rrspeed
1983 C-30 Gage problems
I recently replaced my blown 6.2 diesel with a .030 over 454 in me restored 1983 C-30 crew cab dually I use to tow my car trailer. To make a long story short, the dash gages were working fine after the swap. I have a volt meter, oil pressure and water temp gage as well as mechanical gages. I had to replace the hydro boost unit and after I did, I noticed the oil pressure and water tempature gages weren't working. The oil pressure gages read at the max. (80) and the water temperature gage doesn't move at all. I already checked the wires going to the senders and they are ok. The senders check out as well. The only other thing I did was disconnect tyhe power amp and radio. I'm wondering if the ground for the radio might also be a common ground for the oil pressure and water temp. gages. Any suggestions would be greatly welcomed. I tried another set of factory gages we had from a truck that we were scrapping and they did the same thing. I'm using a Summit street/strip ignition box, distributor and amplifier. The ignition requires a diode to be used in the alternator wiring to prevent run-on. I'm wondering if that might be affecting the gages as well. It just seems old that only the oil and water temp gages are affected and not the voltmeter.
rrspeed is offline   Reply With Quote
Old 10-17-2008, 04:02 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: 1983 C-30 Gage problems
Yeah it's gotta be a ground and definitely something you recently touched...
