Old 10-17-2008, 04:31 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
A/C evaporator memoval
can the evaporator be replaced all from out side the fire wall? or is there something need to be removed from inside the cab?, is it an all day issue getting it out and putting a new one in?
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 10-17-2008, 06:36 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: A/C evaporator memoval
The evaporator is on the outside of the firewall. The heater core is on the inside. There are four bolts/screws that hold the housing to the firewall. I would be a fool to tell you it's easy, but having the front cap off and the engine/transmission out makes it easier.....as in my case. You'll have to do some mild acrobatic stunts in getting in/under the dash to get all of the stuff out if you get into it like I did. Hopefully, you won't find what I did when I got the stuff off of the firewall of my truck. Can you say....rust?
The bolts/screws that go through the firewall go into the heater core housing on the inside of the cab. Hopefully, seeing these pix will help you understand how much it sucks to have my problem, but my experience so far has been deconstruction (Ty Pennington calls it "DEMOLITION!!!") and not reassembly. I have to replace my firewall/cowl before I can get on with life in the slow lane.
Good luck.
Member Nr. 2770
