10-17-2008, 04:48 PM | #1 |
Always on the hunt...
FS: 67 Ignition Retaining Nut/Spacer/Lock Set - Oregon
Complete matched setup pulled out of a recently parted 67, ignition switch and door locks are in good working order. Setup includes two matched keys, ignition lock cylinder, ignition switch spacer, ignition switch nut, ignition switch and both door locks w/pawls & retaining clips. $35... shipped lwr. 48/payment by paypal, check or money order.
10-17-2008, 09:56 PM | #2 |
Re: FS: 67 Ignition Retaining Nut/Spacer/Lock Set - Oregon
Do you have the keys for the door locks? Also is they're any pitting? Thanks, Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) Last edited by 4bynut; 10-17-2008 at 09:59 PM. |
10-17-2008, 10:02 PM | #3 |
Moderator
The ignition key and the lock keys are the same, that is why it is a matched setup
10-17-2008, 11:15 PM | #4 |
OK, thanks leddzepp. Then if their not pitted i'll take them. LMK. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
10-18-2008, 12:12 AM | #5 |
If these will fit through '72, I will take the set if it is still available. If this is a "go", please PM me so we can make the payment arrangements.
Thanks, CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
10-18-2008, 05:29 PM | #6 | |
For wiw: I recently had a local locksmith cut a key for a cab & door set that I had sold and then misplaced the originals, and I was charged $25. for the first key and $2. more for a copy = $27. for just 2 keys. |
10-18-2008, 05:58 PM | #7 |
CCCC, that above pictured ignition spacer and retaining nut are for a 67 only and that setup may be sold to 4bnut, but I do have this 69-72 matched setup with a brand new set of keys available. I would let this setup go for $45. shipped, cost increase is due to spending $27. (see above post) for the pair of new keys on this setup. Lmk,
10-19-2008, 12:17 PM | #8 |
Thanks Classic Bowties. Consider the pictured ign switch/door lock components for 69-72, with keys, sold at $45 including shipping to 87829. Am mailing a check for $45 to you at your address given in PM. I will trust you to mail the parts to my PO Box after you cash the check and have $$ in hand.
CCCC
10-19-2008, 03:53 PM | #9 |
If the 67 setup is still available, please let me know. P.M. me with payment info if they are. Dave
10-20-2008, 04:30 PM | #10 |
10-20-2008, 04:33 PM | #11 | |
10-20-2008, 04:38 PM | #12 |
Hey Dave, giving 4bynut a little more time to get it worked out on his end. I will keep you informed if they are available yet. I do have another 67 ignition switch with retaining nut, spacer and 1 key and if thats all you need I would let it go for $20. shipped. Mel
10-23-2008, 06:35 AM | #13 |
10-23-2008, 10:57 PM | #14 | |
10-24-2008, 01:54 PM | #15 |
Dave, here are some pics of the available 67 ignition switch with spacer, retaining nut and one key. These are 40 year old original parts and as for the condition of the retaining nut, it would work fine for a driver due to having some plier marks on the outer edges from being removed at some other point in it's life. Mel
10-25-2008, 09:38 PM | #16 |
If you still have the 67 ign bezel nut? I will buy it.I don't check here much but my email is SCJKOVACH@AOL.COM
I can pay pal with out a problem Thanks, Steve |
