10-17-2008, 07:19 PM | #1 |
Pedals, from manual to automatic
Looking to replace my manual transmission with an auto and had a question. Is there a difference between the pedal setup between a manual and an auto? I know I left myself wide open for someone to say "Yeah, the clutch pedal...", but what do I need to do to get it to work. Do I need to get ahold of a junkyard automatic pedal set or is there a way to modify and use the manual pedal set I already have?
Thanks, Josh
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears Good judgment comes from experience, and experience, well......that comes from bad judgment. 1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then. |
10-17-2008, 07:26 PM | #2 |
The Older Generation
Re: Pedals, from manual to automatic
Pedal setups are the same. All you have to do is remove the clutch pedal and related linkage. LockDoc
10-17-2008, 07:58 PM | #3 |
its all about the +6 inches
Yep... Leon is dead on right!
10-17-2008, 09:07 PM | #4 | |
Exactly what I just did about a month ago.......here is a before and after picture
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 10-17-2008 at 09:12 PM. |
10-17-2008, 09:14 PM | #5 |
Still livin the "dream" in '54
It's a pretty simple process...
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
10-17-2008, 09:24 PM | #6 |
if you want too you can take out the brake&clutch pedal set theres four bolts than just put in just the brake pedal
10-17-2008, 09:29 PM | #7 |
Fabricate till you "puke"
Why do you guys want to take the clutch peddle out......thats the pc that really makes these old bastards "DANCE"! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-17-2008, 09:34 PM | #8 | |
My automatic dances a hell of alot better than when it was manual!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
