Old 10-17-2008, 10:18 PM   #1
prg machine
prg machine's Avatar
frame swap for a 4x4
I am told that a GMC 2wd frame can be converted to a 4x4 by using the front spring hangers from a K truck and a front crossmember????
Does anyone know for sure how this is done?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 10-17-2008, 10:44 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: frame swap for a 4x4
I'll move this to the 4X4 section. They can probably tell you every little tidbit you need to know.
With that being said... I *THINK* it can be done, and probably takes what you listed, and then the 4X4 steering gear box and a few other odds and ends.
Old 10-17-2008, 11:21 PM   #3
prg machine
yea, I posted around in frame and suspension and the 4x4 forum and here also hoping for attention.
does the steering box bolt to the 2wd frame without trouble?? I never thought there would be a difference. I have everything on my K truck to swap over. I straightened the frame as best I could but it still favors pulling slightly right, just enough that I know it and wish it didn't. For now the truck is used minimaly and only short distances. Someday I would like to swap.........................or find a shortbed frame!!!!!!!!
383 .040 over
Old 10-18-2008, 10:54 AM   #4
sweet70beast
sweet70beast's Avatar
I know a guy that did just that. He told me that other than a few minor things it is basicly a bolt in, all the holes are already there. I didn't see the before but I did see the after and you'd never know it was a conversion. I've got my eye on a 71 Chev with rear leaf springs and if I can get my hands on it I will do a conversion to it.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 10-18-2008, 11:22 PM   #5
GMCMAX
Active Member
GMCMAX's Avatar
All the holes aren't there, but it's not hard to drill the ones that aren't. If the 2wd frame has rear leaf, you're a step ahead. One of the PITA things on my 68 was flattening out the dimples in the front where the e-brake cables go through. The other was that the 2wd rear end spring hangers are shorter and it took a 4" block to make it sit level with the stock 4X4 front springs.
The 4X4 power steering box bolted right up on mine.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 10-22-2008, 04:13 PM   #6
prg machine
and is there any difference in the 3/4 ton to the 1/2 ton frames in consi9dering this swap????
383 .040 over
Old 10-22-2008, 06:35 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Like mentioned all the holes are not there. Mainly for the shackle mount for the front spring. I am in the process of doing this to my 72 longhorn. When i get it far enough I will post up pics and info. I am planning on cutting the part of the frame where the e brake knotches are and installing a flat piece of steel there so it looks factory. I may even replace the rear spring hanger because I am using 6" lift springs in the front and if I don't replace that hanger, I will need a 10" block. LOL I think the biggest difference in the frames, is the 1/2 frame rail heighth is shorter than the 3/4. But I am not 100% on that.
Dieselwrencher is offline   Reply With Quote
Old 10-22-2008, 06:36 PM   #8
Dieselwrencher
And another thing, you will need the bumper brackets from the 4wd truck in the front because 2wd and 4wd are different.
Old 10-24-2008, 10:51 AM   #9
maximum destruction
In House Collision Technician
actually, the 1/2 ton & 3/4 ton frame heights are the same, as well as some 1 tons. the rails are indeed taller on 1 tons that were designated for dumps, box trucks, ambulances & military cucv's.
MAXIMUM DESTRUCTION
maximum destruction is offline   Reply With Quote
Old 10-24-2008, 01:02 PM   #10
prg machine
so 1/2 ton and 3/4 ton frames were the same dimensions and material strength?
383 .040 over
Old 10-24-2008, 02:36 PM   #11
Jtrux
I'm a poor spectator
Jtrux's Avatar
Interesting thread, I have a 69 chevy parts truck with rear springs, might have a new project after all.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-24-2008, 04:05 PM   #12
maximum destruction
as far as i know, the 1/2 & 3/4 trucks, blazers, & suburbans use the same thickness in the steel. 1 tons are thicker & as i said before, depending on their intended use, some had a physically taller rail. however, i don't remember the time span when gm changed the steel in their frames. i believe late 70's or early 80's.? maybe someone else here can pinpoint that for u.
MAXIMUM DESTRUCTION
Old 10-24-2008, 05:07 PM   #13
prg machine
okay, I have located a 1/2 ton longbed frame from a chevy with the rear leafs. The guy thinks that the 1/2 ton might have a slightly narrower, like 1 inch per side or so, set up in the rear spring hangers or the rails themselves, than the 3/4 tons?????
I guess the problem is putting the 3/4 axles under the 1/2 ton frames in the rear.
anyone know anything about this fact???
383 .040 over
Old 10-24-2008, 05:34 PM   #14
padresag
4 x 4 frame is 1" higher than a 2 x 4 frame in the trans-t/c area
ron
padresag is offline   Reply With Quote
Old 10-24-2008, 05:48 PM   #15
Dieselwrencher
I am going to measure this blazer 4x4 frame I have and the longhorn frame I have to compare. I never have done it, the 3/4 tons just look bigger in the frame area I guess?
Old 10-24-2008, 06:11 PM   #16
padresag
measuring your blazer frame and your longhorn frame is going to tell you what?
I do have a suburban 2 x 4 frame and my panel 4 x4 frame and the 4 x 4 is 1" deeper. mine are same year , same w/b
ron
Old 10-24-2008, 09:22 PM   #17
prg machine
so what about the width at the rear spring hanger area????
383 .040 over
Old 10-24-2008, 09:41 PM   #18
padresag
don't know. best thing to do is find the chassis in question which is opposite what you have and measure it for yourself; then you know exactly what the differences for. you will get a variety of answers on these boards. always confirm what you need to know and that will alleviate any foreseeable problems
ron
Old 10-24-2008, 10:03 PM   #19
manimal
manimal's Avatar
look for grendel he has done this and posted the whole build up. AWESOME work he's done. Good Luck
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-25-2008, 12:12 AM   #20
GMCMAX
Active Member
GMCMAX's Avatar
Dang, sorry, it's for 73-87.......... thought I had another link for ours, but can't find it.
Check this link from Chuck's Chevy pages, it gives frame dimensions
http://www.chuckschevytruckpages.com/framespecs.html
Gets More Chicks
Old 10-25-2008, 01:34 AM   #21
Dieselwrencher
Originally Posted by padresag View Post
measuring your blazer frame and your longhorn frame is going to tell you what?I do have a suburban 2 x 4 frame and my panel 4 x4 frame and the 4 x 4 is 1" deeper. mine are same year , same w/b
ron
It will tell me that a 4x4 1/2 ton frame is different than a 2x4 3/4 ton frame. This is what I found in my measurements.
These measurements were taken from top to bottom of frame flanges. And both frames were 1/4" thick. The Bold is for the longhorn to try to see the difference in the post.
1972 Blazer 4x4 1/2 ton 1972 Chevy Longhorn 3/4 ton 2x4
6 1/8" tall behind front cab mount 7 5/8" tall behind front cab mount 1 1/2" difference
4 1/2" Tall above rear axle 5" Tall above rear axle 1" difference
Rear Spring Hangers On Frame
Front Front
10" 5 1/2" 4 1/2" difference
Rear Rear
7 1/4" 7 1/4" Same
So what this shows me is that the frames are different from 1/2 ton to 3/4 ton. Now this could be different with the 2wd coil spring rear suspension trucks. But not with the leaf spring 3/4 ton trucks. Basically the 2wd 3/4 ton frame I have is the same as a 4wd frame almost. Since some holes are different up front I realize they are different. But that shows a comparrison on frame heighth.
And for the rear leaf spring hangers. I had it backwards. Everyone told me the rear hanger was longer on the 4wd's than the 2wd's. Well in reality it is the front hanger that is almost 4 1/2" longer than the 2wd one. That is a big difference. And the rear ones are the same.
Last edited by Dieselwrencher; 10-25-2008 at 01:48 AM. Reason: Bold info to tell difference
Old 10-25-2008, 01:38 AM   #22
prg machine
the "S" dimensions don't make any scence to me for longbed/shortbed trucks................??????????
383 .040 over
Old 10-25-2008, 02:36 AM   #23
padresag
Front Front
Rear Rear
7 1/4" 7 1/4" Same
what I can't understand is trying to figure out a comparison between a blazer chassis to a 3/4 ton chassis,.I can see comparing a 127" w/b 1/2t 2 x 4 chassis to a 127" w/b 3/4t 4 x 4 to see what the differences are other than crossmembers and suspension orientation.
ron
Old 10-25-2008, 08:58 PM   #24
Jtrux
Jtrux's Avatar
ron
It's because it's what he has, the comparison is between a 1/2 ton and 3/4 ton more specifically 1/2 ton 4x4 to 3/4 ton 2x4.
Old 10-25-2008, 09:32 PM   #25
prg machine
what the.............?????
can't believe how many variations of the same thing we can come up with here.
sounds like the 4x4 frame is a little taller at the transfer case area....................and since anything can be done..................the 2wd rear leaf sprung longbed truck frame will work for a 4x4 conversion.
I think!
383 .040 over
