Old 10-18-2008, 02:10 PM   #1
B17CRX
B17CRX's Avatar
quick ?, how to remove
Getting ready to install new style tie rod ends and tie rod on my 55 2nd series and I would like to know how you guys have removed the old ball studs from the steering arms??
-Joel
B17CRX is offline   Reply With Quote
Old 10-18-2008, 02:40 PM   #2
prostreeter58
prostreeter58's Avatar
Re: quick ?, how to remove
get yourself a set of pickle forks..........Sears carries them..........
prostreeter58 is offline   Reply With Quote
Old 10-18-2008, 03:01 PM   #3
B17CRX
B17CRX's Avatar
No not those, on the left and right there are two ball studs that fit into the ball sockets on the ends of the tie rod. The new style tie rod ends need a hole to go into and so either the old ball studs need to be drilled/cut out or maybe I need to have a machine shop press them out???
-Joel
Old 10-18-2008, 03:03 PM   #4
pugs
pugs's Avatar
lokk at the ends usually a cotter pin is there remove it and what looks like a slot at the end will actuall unscrew and release the pressure on the spring inside and that will release pressure on the inner ball lock
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 10-18-2008, 03:24 PM   #5
B17CRX
B17CRX's Avatar
10-4, thats done. but now I need to get the ball stud removed from the steering arms to make room for the new tie rod end to bolt to. maybe I need to post a pic on what I am talking about?
-Joel
Old 10-18-2008, 03:31 PM   #6
pugs
pugs's Avatar
i believe the are pressed in,maybe alittle heat will help, but i dont believe the newer style ends will work anyway not enough of a cast end to make it seat properly
Old 10-18-2008, 04:16 PM   #7
B17CRX
B17CRX's Avatar
hmmm, that doesn't seem right. If the newer style ends don't work then why would LMC and others sell them and say that the old style ball and socket ends are no longer available and also not particularly safe if worn?
Someone here must have performed this swap successfully and has some tips to share.
-Joel
Old 10-19-2008, 12:57 PM   #8
Knothead
Knothead's Avatar
Yes, You are correct about needing a press to get the old ones out. I filed the ends until you can see where the two pieces join, It took a hyd. press to get them to seperate.
Knothead is offline   Reply With Quote
Old 10-19-2008, 01:43 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Drill the center out with a 1/2" drill bit and drive the ball out with a drift and hammer. They come out very easy that way.
dwcsr is offline   Reply With Quote
Old 10-19-2008, 03:46 PM   #10
B17CRX
B17CRX's Avatar
I'll give it a shot.
-Joel
Old 10-20-2008, 02:39 AM   #11
55dude
55dude's Avatar
hey dude post some pic's as you go along for the next guy.
55dude is offline   Reply With Quote
Old 10-21-2008, 12:23 PM   #12
B17CRX
B17CRX's Avatar
Ok, so I broke a drill bit and one of my punches, but they are out! I went ahead and added the step by step pics to my build thread.
http://www.67-72chevytrucks.com/vboa...67#post2939467
-Joel
