Old 10-18-2008, 08:31 PM   #1
orbot
orbot's Avatar
carb throttle linkage spring
Are there any issues if i use a stiffer spring??
orbot is offline   Reply With Quote
Old 10-18-2008, 08:44 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: carb throttle linkage spring
If you are referring to the throttle return spring I put a stiffer on my 97 and it made the pedal harder to hold a steady cruising speed. Made it more difficult to shift as well, It got removed......
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
