Old 10-18-2008, 10:21 PM   #1
byarber
64 GMC K1500 Power Steering Conversion
I Am doing an off frame restoration on a 64 GMC k1500 and am just finishing the framework before I mount my cab. I mounted a 2wd PS gear and am having problem connecting my steering shaft that the pitman arm connects to to the arm on the ball knuckle.Can anyone tell me what I need to complete this conversion.Thanks,Blaine
byarber is offline   Reply With Quote
Old 10-19-2008, 05:25 AM   #2
68K20 x Drill
Re: 64 GMC K1500 Power Steering Conversion
If it is like my 68, You need either a crossover steering conversion, or a 4x4 steering box.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-19-2008, 08:05 AM   #3
byarber
Thanks for the reply.I dont think there is a difference in the power steering boxes for a 4wd .The shaft in both come out the bottom unless you know a steering box on a model that comes out the side.Thanks,Blaine
Old 10-19-2008, 08:11 PM   #4
71 super
71 super's Avatar
The boxes look the same but the pitman attachment is different. You will have to have a 4x4 box. You should be able to come up with one reasonably in a salvage yard off off of a 73 up truck. If you will sen me your email I will send you pics of my 4x4 setup (stock 72) Harold
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 10-20-2008, 12:35 AM   #5
Captainfab
60-66 Nut
If the '73 and up 4x4 box doesn't work for you for some reason, another option is a ps box off of a Dodge 4x4. In the late '70's Dodge used saginaw boxes on a bracket that turned the box 90* so that the sector shaft is horizontal and the pitman arm is verticle.
