10-19-2008, 12:41 AM | #1 |
door gap adjustment
on a 78. any tips? i need to rotate the top of the door forward. i loosened the hinge to pillar bolts accessible from the outside but there is one from the inside i can't seem to access. looking for some how-to here. thanks!
79 K10 77 MGB 79 Kawasaki KZ1000 Last edited by bucket; 10-19-2008 at 12:42 AM. |
10-19-2008, 01:09 AM | #2 |
Re: door gap adjustment
Here's a pic of the drivers side hole. You pop out the plug with the white wire in it and the bolt is down in the hole. The passenger side is the same, you just take out the glove box door. The white wire goes down to the door jamb switch for the dome light.
10-19-2008, 01:13 AM | #3 |
If I remember correctly . Use a ratchet , extension, and 9/16 socket and there is a hole in the cab on the inside . You will need the short extension to reach the outside of the cab . Crawl under the dash and you will find a hole in the same location as the bolt tip on the outside . I dont think it was that hard to get to .
Frank
Born and proudly residing in a Red State ! |
10-19-2008, 01:33 AM | #4 |
thanks fellas. i remember a wire and grommet being right where i thought the nut should be.
79 K10 77 MGB 79 Kawasaki KZ1000 |
