10-19-2008, 11:15 AM | #1 | |
The One And Only !!!
Carb Problems......
Hello all speed freaks,
I posted this in the engine section; Quote:
Since this is a pos Demon with Holley float valves and no id numbers how would I determine which Edelbrock carb would run this 502 ? The only info I have is it's a 97 (installed when truck was new) with iron heads in which I believe would be the 450 hp version. Could someone shed some light on my situation ? Thanks
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
10-19-2008, 01:03 PM | #2 |
Re: Carb Problems......
streetable carb cfm = rpm x displacement / 3456 x 0.85
6000 x 502 / 3456 x 0.85 = 740.8cfm racing carb cfm = rpm x displacement / 3456 x 1.1 6000 x 502 / 3456 x 1.1 = 958.7cfm I'd say a 750 - 800cfm will do just fine for a driver, that "racing carb" figure sounds extreme.... granted I had two edelbrock 500cfm four barrels on a cammed 454. Last edited by Mykk; 10-19-2008 at 01:07 PM. |
10-19-2008, 01:21 PM | #3 |
This truck is no racer but just a show cruiser so I would think the 750/800 would do me just fine.
Thanks for the help Mykk.....
10-19-2008, 09:39 PM | #4 |
buy a fuel injection setup for it!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-20-2008, 11:34 PM | #5 |
Ditch the Demon. Buy a used Holley 3310 750 vac secondary carb. Order a Proform main body and secondary block so you can jet the back. Install said parts with fresh rebuild (I like the Barry Grant kits). Drive the wheels off of it....
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
