Old 10-19-2008, 11:23 AM   #1
newbraunie
newbraunie's Avatar
Did I use wrong lube for t-case and trans?
I should have browsed the threads first before changing out lubes on t-case and trans. I have a Rockwell T221 & SM465. I used GL5 85-140W. I thought the heavier weight would be better with the heat here in TX. I read in the threads that most use 85-90W lube. Should I switch it out to 85-90W?
newbraunie is offline   Reply With Quote
Old 10-19-2008, 01:07 PM   #2
DieselEater
DieselEater's Avatar
Re: Did I use wrong lube for t-case and trans?
You should be fine.....
A..........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
