Old 11-22-2002, 11:04 PM   #1
67cst
i love summertime
67cst's Avatar
what year tilts have the same wire harness as a 67 3 on the tree column
hey guys i wanna get a tilt for the 67, what year tilts have the same wiring harness? What will plug right in? hope this makes sense
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 11-23-2002, 12:16 AM   #2
Hooter
My other Love
Hooter's Avatar
all the chevy steering columns from 66-87 have the same turn signal harness plug
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-23-2002, 12:55 AM   #3
Rod
Well never seen a 3 spd tilt so if your going auto or 4 spd tilt... the plug for the signal switch isnt your real problem.... adapets available...it's more if you want the reverse lights to work off the wiring harness you already have... your 3 spd has wiring off the columns lower switch to activate the reverse lights. The four speed harness for reverse leads to the switch on the tranny. An automatic tilt has the reverse and neutral safety on the columns lower switch. Pretty much you gotta say what tilt you wanna put in before any advise I can give. And are you going floor shift hurst type unit or something like that?
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-23-2002, 02:36 AM   #4
67cst
i love summertime
67cst's Avatar
rod-i have a lokar floor shifter for it, i want a tilt column for it, all i wanted to know was what years will the main wiring harness plug into? ( i wanna find something that the 67 will plug right into) does that makes sense?
THANKS,
DEREK
Old 11-23-2002, 08:41 PM   #5
Rod
Grab the kinda tilt you want,probably a van one will work for you, but you run into the problem of a lever stub with a van automatis one... havent tried to put a 4 spd cove ron a automtic tilt... may do that to see if it can be done.
Anyway as for harness plug capabilties.... find a flat wire to curved wire adapter.... if you cant find one give me a email. Van column from likr 73-84* will work.
They look like this one........ on ebay even.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872719082
Old 11-24-2002, 02:16 AM   #6
67cst
i love summertime
67cst's Avatar
rod, THANKS FOR THE INFO! great help
