Old 11-22-2002, 11:14 PM   #1
monypit
monypit's Avatar
Question reluctor kit
has anyone out there installed one of the Stealth conversions reluctors on the 4l60e before. just looking for some advice before i tear out the 203 and try to break something again. I put the short shaft kit int eh trans so the 203 would work hopefully that wasn't a mistake
1973/1997 Blazer/Tahoe (it just doesn't know that it is a '73)
monypit is offline   Reply With Quote
Old 11-23-2002, 01:36 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
I guess I am stupid..
what the heck is a reluctor?
and
what the heck is a 4l60e?
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 11-23-2002, 02:03 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
First, monypit, I haven't done this, so I'm not any help to ya. Sorry.
Scrub, a 4L60E is the electronic version of the 4L60, which is the new name GM started calling 700R4 overdrive trannys in the early 90's. The E means it's computer controlled.
I'm not sure what he's calling reluctor myself. I've got a guess, but let's let monypit tell us what it is.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-25-2002, 05:07 PM   #4
PHOENIX
Thumbs up
Hey Mike I noticed you put "You get what you pay for"
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 11-30-2002, 01:36 AM   #5
monypit
monypit's Avatar
a reluctor is called a tone ring by ford and is what the Vehicle speed sensor "sees" when it is rotating usually on the output shaft of the t-case in 97 and newer gm trucks. I put a 97 Tahoe motor and trans in my 73 but since i have a right hand drop tcase I couldn't use the modern tcase. Stealth conversions has a kit that solves this problem by putting the ring on the govenor gear of the output shaft and drilling and tapping a hole in the thick part of the case between the tcase and the trans.
There isn't anything wrong with the 4L60E trans they fixed a lot of issuies that the 700 had and they even make a stand alone computer to run it but when you have the complete engine and trans with the harness and computer and Dash even it runs great. it will run better when it starts getting a signal from the speed sensor. Go to Vortec conversion in this forum to see what I have been doing since Jan if you are interested. I have to start a photo account and update the link so don't be surprized if that one stops working.
Old 11-30-2002, 02:26 PM   #6
swervin ervin
I always called the disc on the output shaft for electric speedos, signal generators. Reluctor sounds good too. I figured this was what you were talking about.
Mike
