Old 10-19-2008, 06:17 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
leaking tranny fluid from the dip stick tube
i recently installed a new motor in my truck and after everything was buttoned back up, i noticed that there is a gigantic tranny fluid leak coming from the dip stick tube where it meets at the transmission. i remember that there was an o-ring where it mates up but there is no telling how old that is. what can i do to fix this leak?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 10-19-2008, 06:29 PM   #2
truckdude239
truckdude239's Avatar
Re: leaking tranny fluid from the dip stick tube
which trans mission? there is a rubber grommet on the tip stick that needs to be replaced put some good sealant on it put ti back together let it sit a day you should be good to go
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-19-2008, 06:44 PM   #3
MotorSeven
Restoration Desperation
MotorSeven's Avatar
If it's a turbo 350 or 400, go get a newer style tube & dipstick. It has a large grommet instead of the O ring & does not leak. Also, are you sure you have the right tube/stick? If not you may be over filling which will cause leaks and other more costly tranny repairs.
RD
MotorSeven is offline   Reply With Quote
Old 10-20-2008, 03:37 AM   #4
crm318
crm318's Avatar
its the original stick and its a th350. can i find a new grommet for it?
1972 Cheyenne
Old 10-20-2008, 07:03 AM   #5
truckdude239
advance auto carrys them in there help section
David fuller
2000 Tahoe 5.3l 378
Old 10-20-2008, 12:43 PM   #6
Rons86
Rons86's Avatar
If it's not already, the dipstick needs to be bolted to the transmission/engine or it will move around and leak again after a short while.
Rons86 is offline   Reply With Quote
Old 10-20-2008, 03:28 PM   #7
crm318
crm318's Avatar
i dont think that there is anywhere on the dip stick to bolt it down. if the truck is sitting level, does it mean that there is too much fluid in it?
1972 Cheyenne
Old 10-20-2008, 03:47 PM   #8
CG
BlahBlahBlah
Are you talking about a small leak or is it pouring out? I had one that was pouring, and was told there was a vent tube that was probably clogged or pinched. It wasnt a trans I was going to use anyway, so I never looked any further.
Old 10-20-2008, 05:26 PM   #9
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
I put a new O-ring on mine and wrapped a little Teflon Tape around it and it hasnīt leaked since.
The tube is also bolted to the Transmission like Rons86 said.
If it isnīt tight and can move around, you will never get it sealed right.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 10-20-2008, 07:29 PM   #10
1970heavychevy
busted knuckles
1970heavychevy's Avatar
I had that same problem. I tried using a new one with the o-ring but didn't work, so I taped it but got worried that the heat would melt the tape and end up inside. I finally found one at the junk yard that had the grommet. New grommet from O'reilly's and it does need to be bolted down. Might have to tack weld a tab if nothing to mount with.
1970heavychevy is offline   Reply With Quote
Old 10-20-2008, 10:54 PM   #11
MotorSeven
MotorSeven's Avatar
If it has an O-ring, you can't put a grommet on it because the tube is too big. The newer style has a narrower tube to acomodate the grommet. I can tell you this, Advance, OReillys, & Autozone do not carry the newer style. I found one at a ma & pa auto parts store($14).... you may have to look on line for one, or maybe try a CHevy dealer. & yes it does have to be bolted to the upper tranny bolt. There is a bracket on the tube for this.
RD
Old 10-21-2008, 04:37 PM   #12
crm318
crm318's Avatar
yeah, mine is bolted to the transmission. ill try the teflon tape.
1972 Cheyenne
Old 10-21-2008, 10:01 PM   #13
Green Machine
Green Machine's Avatar
Fixed ours like this - cleaned the tranny hole and dipstick end with some brake cleaner on a rag, got a new o-ring and put thin film or black ultra silicone in the tranny hole and a little more on the dipstick end. Bolted the dipstick up and let it sit over night. Did the same with the kickdown cable. No more leaks !!!
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
