Old 10-19-2008, 09:35 PM   #1
jlaird
jlaird's Avatar
HOW TO: One piece floor pan install
This is going to be a thread I update periodically, so try to be patient with me
So...I bought this BEAUTY of a cab up here in the northeast where it like finding a needle in a haystack. Every bit of this cab is mint except the cab supports, and the usual rockers, cab corners, etc. Same ol song and dance. I thought this was a great opportunity to purchase Tri-pros new one piece floor. I ordered the floor, both sets of A and B pillar patches, kickpanel patches, rockers, and cab corners.
The cab is a 68 C-30.
Here are some closeups of the carnage:
I know what your thinking, " that floor looks pretty nice!" Yes, it was, but all the cab supports are gone, so instead of screwing with replacing all those, I got this:
OHHH, isn't she purdy!
So the first step I took was to brace this bad boy up. The more the better I believe. So I put two braces from the rear wall to the firewall, and then tied those together. Then I ran some across the door openings, and tied those together. Lastly, I ran two vertical braces to tie the upper and lower together. Hopefully this will do the trick. Other people I have seen do the floor swap only put the first two braces in from rear wall to firewall and they did not report any issues with movement, so I think I am all set.
After the cab was braced, the first thing I did was remove the rockers. This is the first time I've done any sheet metal work, so I was expecting this was going to be a....well you know. Anyway, the rockers came out real easy! I was pleasantly surprised. The first thing I did was clean off the area to find the spot welds, then I center punched them.
jlaird is offline   Reply With Quote
Old 10-19-2008, 09:36 PM   #2
jlaird
jlaird's Avatar
Re: HOW TO: One piece floor pan install
I got this spot weld remover from harbor freight and was expecting it to be junk, but it actually worked really well.
It popped right off with a little chisel work:
Here it is removed:
After I got both rockers off, I drilled out the spot weld on the firewall lip.
Sometimes it may be hard to find the spot welds. I found that if you take a angle die grinder and lightly hit the area, the spot weld will show up for ya. Also, a little soap and water helps too.
After I got the spot welds drilled out on the firewall, I went in the cab and cleaned out all the factory seam sealer and started to separate the floor and the firewall. I made a slice with an angle grinder about an inch away from the seam. Then removed the remaining piece between the cut and the seam.
Again, this came out really easy. I hope Im not jinxing myself
Old 10-19-2008, 09:36 PM   #3
jlaird
jlaird's Avatar
Ok, time to do the rear seam. I drilled out the spot welds on the rear of the cab.
So this is as far as I got this weekend. Until next weekend...
Old 10-19-2008, 09:46 PM   #4
Rokcrln
Rokcrln's Avatar
No I don't think so, get you lazy butt back out their and give us more!
Looks great so far. I take it the new floor has all the mounts and bracing built in to it? I have thought about doing this same thing on my 70 2WD Blazer but I think by the time it is all done their will not be much factory floor left. But once the DropMember is installed and I see what is going to need to come out for the 5.3 and 4L60E I will keep the idea out their.
I found if you use some form of cutting fluid with those spot weld drillers they will last quite awhile.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-20-2008, 09:19 AM   #5
68 short step
looking really good......
68 short step is offline   Reply With Quote
Old 10-20-2008, 09:40 AM   #6
jaros44sr
jaros44sr's Avatar
Nice work, that A post doesn't look to bad, compaired to some of them. Good bracing, the more the better. Thanks for showing that spot weld remover, I thought they cut a big hole thru both pieces of metal, now I gotta get one. Plus Rok's idea of the cutting fluid
Frame looks great, any more pics of it when your post up your progress would be cool
I think that's a steal for 360, compaired to all the work you will save...Subscibed
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-20-2008, 10:21 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Yeah, what the crap, you quitter!
Looks GREAT! For some reason I like threads like this more than the "trucks all done, here it is" threads.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-20-2008, 10:48 AM   #8
woodridge
woodridge's Avatar
Yeah, that's right, just leave us hanging.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 10-20-2008, 12:19 PM   #9
revn67
revn67's Avatar
i will definitely be checking back with this...i live in the northeast and i have 2 cabs, and one will need a new floor so i was thinking of using the triplus floor panel...looking good so far though!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 10-20-2008, 01:41 PM   #10
jb4short
Damn Yankee
jb4short's Avatar
Did Chris buy your other cab?
jb4short is offline   Reply With Quote
Old 10-20-2008, 01:51 PM   #11
jlaird
jlaird's Avatar
Yes he did. Actually, I GAVE it to him for free! Good guy...
Hey Jon, when will those two pieces on backorder arrive?
Josh
Old 10-20-2008, 01:53 PM   #12
jlaird
jlaird's Avatar
Check my build thread in sig, pics galore in there.
Josh
Old 10-20-2008, 02:21 PM   #13
jb4short
Damn Yankee
jb4short's Avatar
Josh
I'll check- I know one was the 25th.
Did Chris mention what he planned on doing with it? If you see him tell him to come down and do some more bodywork...LOL
Old 10-25-2008, 09:48 PM   #14
jlaird
jlaird's Avatar
Got a chance to do some more work today. The first thing I did was get the cab on its back. Then I decided to add more bracing. Fore anybody doing this, i would recommend additional bracing as close to the floor as possible. After I got the floor out, the cab is a bit flimsy, but honestly, I think this is going to happen no matter how much bracing you put in. In this pic, you can also see the slice I put in the floor near the rear wall.
Here is the additional bracing I put in the cab from the firewall to the center supports:
I also made use of the threaded holes in these cab supports:
The only thing left to do was remove the spot welds where the outrigger meets the firewall supports:
And shes OUT!
Anybody need a patch?
Thats it for today. Hopefully I will be able to work on it tomorrow.
Old 10-29-2008, 08:37 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That thing is coming right along, keep up the good work.
Great idea for a thread too.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-29-2008, 10:08 PM   #16
joe231
joe231's Avatar
that is cool!
looks like an entire floor is the way to go!
any one know if there any plans for a '63-'66 floor?
CHEVY ONLY
Old 10-29-2008, 10:26 PM   #17
jaros44sr
jaros44sr's Avatar
Nice work, keep it going...I'll try to check out your build thread when I get a minute, kinda busy right now, but thanks for the link
SAFETY FIRST
AS usual, off topic
Jim
Old 10-30-2008, 04:32 AM   #18
ERASER5
ERASER5's Avatar
Watching closely. I have 2 trucks with bad floors.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-30-2008, 09:10 AM   #19
67ChevyRedneck
Actually, I do!
As long as shipping isn't to $$$ I'd like to get the low hump. I think I need the whole thing, the PO of my truck cut about 3 different holes for shifters in the floor, and the majority of them go all the way to the left of the hump and one is at the top
Let me know, I'm in no hurry, probably won't even get around to it for a couple years, but it would be nice to have it
Jesse James
Project "On a Dime"
Old 11-02-2008, 09:05 PM   #20
rustaddict
Im liking this one peice floor install and I cant wait to see the finished product. I didnt know a one peice floor was available until just recently. Are the inner rockers part of the assembly? Does it come with the seat mounting holes already in it or do you have to drill your own?
71 Cheyenne
55 Chevy hardtop
53 Farmall Super A
92 Chevy Silverado daily driver (284k on the original clutch and still counting)
rustaddict is offline   Reply With Quote
Old 11-05-2008, 10:31 PM   #21
RCbowtie69
RCbowtie69's Avatar
looking good, keep up the hard work, like to see it done, tri pro has a site were they put a floor pan in, not to many picture's of the installation. Keep the pictures coming.
RCbowtie69 is offline   Reply With Quote
Old 11-07-2008, 01:29 PM   #22
ERASER5
ERASER5's Avatar
TTT. I don't want lose track of this one.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 11-07-2008, 02:27 PM   #23
jb4short
Damn Yankee
jb4short's Avatar
The "inner rocker" is actually the "Outer floor" and that area is part of the floor assembly. The seat holes are there along with the nuts welded to the underside.
Old 11-08-2008, 12:15 AM   #24
jlaird
jlaird's Avatar
The floor will be in this weekend. Unfortunately, i am having some problems with the fit of the floor flange at the firewall, particularly at the tranny hump. Theres about a 1/2 gap at the hump. Its too large to hammer. I'm going to have to cut it out and make a new piece. It sucks to have to cut that new floor, but its got to be done. I was thinking about the other people that documented the floor install on this board that didn't have this problem, but there might be a reason for that. msgross has a high hump so he didn't have to match the hump up with the firewall. The other, Tri-Pro, used their new firewall replacement, so again, didn't match up a stock firewall hump to the floor.
Here is the gap:
Old 11-08-2008, 10:07 AM   #25
msgross
msgross's Avatar
Nice thread, I didn't document mine that well... Glad to see that you added extra bracing to the bottom of the firewall... Mine had some flex in the A-pillar area since I had to pull off the door frame bracing to hang doors before final welding...
I found it easier to drill out the spotwelds on the back and front lip so it was ready for plug welding with the new floor... I did just pick up on of those cutters though since I pulled off my firewall braces and found that drilling those out wasn't such a good idea. I had a lot of rust hiding behind them though so i'm glad I did, it also helped me get the floor in... Looking good,
Hope I don't spoil the ending but here's the "high hump" mod...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
