![]() Join Date: Oct 2008
how to install carpet over sound deadener correctly
Do you guys use spray adhesive to stick the carpet to your Dynamat or FATMAT>????
Re: how to install carpet over sound deadener correctly
I just set the carpet on top of it. Did not glue the carpet to it. Might want to remove later on.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 10-20-2008 at 06:28 AM. |
I did not use anything other than I also added "JUTE" on top of the dynomat then I just lay the carpet on top of both.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
thanks alot guys. wasn't sure if it would slide and wrinkle up if not fully glued down.
sharp as a marble
![]() Join Date: Jan 2007
Big Al's on it. The last one I did was just like his. Get the floorboards clean, vacuum, and then wipe with a degreaser, to make sure that the FATMAT has every chance in the world to stick. Put it down, and then install the carpet and jute like al describes. The noise reduction in the truck will be unbelievable!!
jute?
Engine n00b
Which one is cheaper?? Dynomat or FATMAT? And how much do you need to do the cab?
Jute is that string stuff that is kind of like burlap that is used for padding under the carpet
well guys i was thinking of using "EDEAD" instead of fatmat or dynamat. I heard that it was just as good and cheaper, some of it is 1 dollar per square foot. check it out and tell me what you all think of it.
http://www.edesignaudio.com/index.php?cPath=1_24 |
sharp as a marble
fatmat is cheaper, and is because it is a bit thinner than Dynamat. I have used both with good results, and bought it on EBAY. about 50% cheaper than anywhere else. 36 sq feet of Dynamat covered my 67 chevelle. 100 sq. feet of fatmat covered a 71 Blazer, and had some left over.
JUTE is the gray stuff on top of BIG AL'S fatmat. it is 1/4 inch thick shreaded material, that was used on all of our stuff from the factory. If you go to your local auto upholstry shop and ask for some jute the will have it, and show it to you. I get the feeling that there are a few of us about the same age as dirt, and then there are the rest of you! ha ha Last edited by cparman; 10-20-2008 at 07:54 PM. Reason: typo |
Jute is the gray factory material that alot of the newer cars have in between the floor and the carpet. Being that I am in the auto business I called my trim shop and they gave me enough to do the whole cab and the back wall.
#13 |
I'm not sure if it was on this site or not, but someone used some type of roofing material that is the smae material as Dynamat. They used whatever it was because you can get twice as much for half the price.
Anyone know what I'm tlaking about?
R.I.P. Scott Kalitta
#14 |
i think you're thinking of roof mastic....i tried to find some at lowes but couldn't find any
#15 |
does that roof stuff work? if i tried it should i double layer it
#16 |
My understanding is that roof mastic has a tar base that stinks pretty bad when installed and the summer heats it up.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#17 |
Oops cant have that. Ill go search evilbay for some cheap dynomat
#18 |
![]() Join Date: Dec 2002
In place of "jute":.... go to a large carpet dealer; preferrably one that installs commercial carpet. A gray or tan underlayment is and was used in many applications. Ask for jute or felt industrial carpet underlayment.... I have gotten this for free when older, worn carpet is being removed from commercial usage.
The material is 3/8 to 1/2 inch thick and acts as soundproofing also.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). Last edited by GMC Jim; 10-21-2008 at 05:42 AM. |
#19 |
Do you glue the jute to the fatmat/dynonat/etc.?
#20 |
No, just lay it on top of it. It does not move once the carpet and the seats are on top of it...
#21 |
Thanks I forgot to mention the jute has an aluminum backing.... where should the aluminum side lay? ::::::> down on the aluminum sound deadener or up contacting the bottom of the carpet (jute side down on the deadener)...
#22 |
Mine did not have the aluminum sound deadener so I really would not know but if I had to guess I would say the aluminum facing down.
#23 |
So how much do you get to fill a normal cab? 25 sqft?
