10-20-2008, 04:53 PM | #1 |
Homebrew rust removal help
If i remember right somewhere on the site i found a link explaining how to remove rust with a battery charger. Does anyone know where i can find it please. Thanks
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
10-20-2008, 05:39 PM | #2 |
Re: Homebrew rust removal help
you can also soak parts for a few days in vinegar been doing that for engine parts from my indian and theres no explosive hydgrogen gas to worry about//i can just stain the vineager and use for salad dressing thankgiving for the freeloaders that visit to go to the turkey rod run
10-20-2008, 06:01 PM | #3 |
Looks good at 20-ft .....
Here's a real home brewed rust remover --- linked article talks about the chelation power (rust removal) of Molasses !!!!!
Haven't tried it yet, but sounds believable. http://www.wr6wr.com/newSite/article...06/wp0906.html |
10-20-2008, 07:34 PM | #4 |
Here's the the page I used to clean my decade old headers....worked like a charm! Did take a couple of days though....they were pretty rusted.
http://www.stovebolt.com/techtips/ru..._derusting.htm
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
10-21-2008, 04:02 PM | #5 |
Hollister Road Co.
I've read aticles where they have made a pool with molasses and cleaned a frame with good results. I haven't used the Molasses derusting but have used the washing soda and battery charger. The problem is the hydrogen fumes and if you use an SS electrode you end up with nasty cadnium and other chemicals you don't want around your kids and dogs. If you use the washing soda use a steel wire mesh and make it surround the part your cleaning. It does take some time so be patient.
10-21-2008, 04:12 PM | #6 |
wire brush then use phosphouric acid
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
