10-20-2008, 04:59 PM | #1 |
3/4 to 1/2 ton Panhard bar
Guys im close to installing the 1/2 ton rear end and removing the 3/4 rearend. Is the 3/4 ton panhard bar the same as the 1/2 ton bar.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
10-20-2008, 06:52 PM | #2 |
A guy with a truck
Re: 3/4 to 1/2 ton Panhard bar
That all depends on what rear you have. If the bar mounts to the diff, you *might* be OK. If yours is currently mounted on the axle tube, it will be too long...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-21-2008, 08:19 AM | #3 |
It mounts to the diff on both
10-21-2008, 08:48 AM | #4 |
A guy with a truck
Maybe someone here can get you a measurement on a stock one. I think they're around 24"...
10-21-2008, 10:01 AM | #5 |
unless you're going for stoch height you're going to probally need aftermarket adjustable panhard bar
10-21-2008, 10:43 AM | #6 |
ASE master tech/machinist
They are close to the same, been there done that with no issues.
"I sit here and I pray in my broken down Chevrolet....." |
10-27-2008, 11:54 AM | #7 |
Ok great Thanks guys.
