PROJECT 7DEUCE
![]() Join Date: Dec 2002
Blazers suck!!!!!!!!!!!
Ok now that I have your attention where can I get rebuild kits for the blazer hatch hinges or can I go to vato zone and get a rebuild kit. Btw hope to have new pics up of my blazer top refinished by the end of the week..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Future TOTM Winner
Re: Blazers suck!!!!!!!!!!!
Is there such thing as a blazer hatch hinge rebuild kit???
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
PROJECT 7DEUCE
idk????
idke...
PROJECT 7DEUCE
Looks like ill have to go grab my calipers on the way to work ...
I might have a decent set of hinges if your not able to rebuild your set.
PROJECT 7DEUCE
ill keep ya posted on what I find kurt..
Back a year or so when I was starting to rebuild my hinges. Still not done!. I took and old pin and matched up a door pin rebuild kit from the help section. That was the advice I got. I think Someone even had a Part# for all the dorman/help parts. I am sure someone will come through with a #
I grabbed a couple of door pins from the Help section. Took one of the old hatch pins with me. Found a couple that were longer than needed, chopped them to length and chamfered the ends.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
