Old 10-20-2008, 07:05 PM   #1
Bentblazer
Bentblazer's Avatar
Motor mount ?
Is this the right amount of gap below exhaust manifold or do I have a bad motor mount?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 10-20-2008, 07:16 PM   #2
cparman
sharp as a marble
Re: Motor mount ?
Two things. One is you need to look at the mount, and see if the metal piece that is bolted to the engine is touching the metal piece that is bolted to the frame. if so then you got a bad mount. I do not know what year your truck is, but are the exhaust manifolds correct for you truck. Both of mine have rams horn type manifolds.
cparman is offline   Reply With Quote
Old 10-20-2008, 09:29 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Motor mount ?
That's not the right manifold so your mounts might not be bad.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-20-2008, 10:09 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
Re: Motor mount ?
He's right, that manifold is from a newer model.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 10-21-2008, 08:25 AM   #5
Bentblazer
Bentblazer's Avatar
Re: Motor mount ?
Looks like a little research is in store. I have saw in previous post the ram horn type manifolds but thought that there may have been something else offered. Thanks for the input. Also it's a 71 Blazer
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
