10-20-2008, 08:30 PM | #1 |
Engine n00b
Water temp gauge?
Whats the troubleshooting process on it? PO installed a tri-guage pack and only hooked up the water temp to it. I would rather 86 this and make the stock guage work. What do I need to replace/inspect (not in that order, hopefully) to get this looking more stock?
10-20-2008, 11:28 PM | #2 |
Msgt USAF Ret
Re: Water temp gauge?
Here's some good trouble shooting info-----http://www.6066gmcguy.org/Electrical-02.htm------------- Scroll down to water temp gauge.
If you buy an aftermarket unit the guage and sender must be resistance compatible or the readings will be off.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-21-2008, 08:40 AM | #3 |
I think to test the sensor you ground the wire and get your buddy see if the needle moves...
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
